Question about D-Link AirPlus DI-524 Wireless Router
Can't find IP to access di-524 (in bridge mode?)
My home network uses a di-524 and a westell 6100 dsl modem. I was once able to access the di-524's configuration by typing http://192.168.0.1 in my browser window, but this no longer works, now i get a page load error. The 'default gateway' in my ipconfig/all lists 192.168.200.1, but when i type that in my browser, I get to the configuration for the westell dsl modem - which is useful, but now i have no idea how to find the address I need to type in order to access settings for the di-524, which apparently need to be changed for the sake of my nintendo Wii. Can anyone help with this?
  • 3 more comments
  • thomasjw76 Dec 16, 2008
    i have reset the d-link router, and i still can't access it with 192.168.0.1, either wirelessly or with a cable plugged in. the internet connection still works on all my computers, i just can't reach the d-link's configuration page as i once could.
    the westell modem's 'connection summary' page says "connection name: routed bridge." i don't see any option on any of its pages to set it in "bridge mode." its dns configuration page has a "discovered local devices" list that shows all of my computers including the wii. i think it's the westell that is assigning the ip addresses.
    i can't change any settings in the d-link configuration because i can't access it.
    i'm not sure what you mean by "the router page." my first guess would've been that you mean the configuration page for the di-524 router, which i can't reach, which is the whole problem...
    the westell modem's main page, which i can reach, has just one ip address, it says "server: 192.168.4.151." i've tried typing that into a browser too, with the same result, a page load error.
    thanks for your patience!
  • thomasjw76 Dec 17, 2008
    an ipconfig/all on the laptop plugged straight into the router with an ethernet cable, i get the same dhcp server, dns server, and default gateway as on the computers that connect wirelessly. they're all 192.168.200.1, which takes me to the page for the westell modem when i type it in a browser. the ip for the laptop itself is 192.168.200.244, which i assume is assigned by the westell modem dhcp server.
    when you say "set the TCP/IP settings on the local area connection to mimic the IP that you get from ipconfig," i'm not sure what you mean for me to change. do you mean i should go into the network connection properties on the plugged-in laptop and uncheck automatic IP and automatic DNS and manually type in the values from ipconfig?
    the westell modem described in the dslreports link must not be the same modem i have, because mine has no options to be set in "bridge mode," none of the "broadband dsl," "configure connection," "protocol" or "bridged ethernet" menu options described in that article. there is a checkbox i can uncheck for "private lan dhcp server enable..."
    i think the way my system was set up, it was the di-524 router that had its dhcp server disabled and all the ips were coming from the westell. plugging directly into the router, i just get the same ip address as before. the only way i got a different ip address, and the only way i could access the di-524 router's config page in my browser, was by disconnecting the router from the modem, which i just tried - thereby disconnecting myself from the internet.
    i'm going to try disabling dhcp in the modem and enabling it in the router and see if that helps, but i'm still just guessing.
  • JDTec
    JDTec May 11, 2010
    you need to reset yor D-link router.
    Also, you need to set your Westell modem in the bridge mode, in order to pass through the modem and use the router to broadcast the IP addresses.
Solution since you can still access the westell what I would do is ping the westell modem and at the same time do a netstat or tracert to find the location.
Posted on Apr 23, 2009
  • D-Link Master
  • 4,338 Answers
Look on the router page and see what the IP, subnet mask and gateway are. let me know
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 16, 2008
  • 1 more comment
  • JDTec
    JDTec Dec 17, 2008
    try connecting the router directly to the PC via one of the ports, not the WAN port. Do an ipconfig and see what address it picks up. Then set the TCP/IP settings on the local area connection to mimic the IP that you get from ipconfig. Then open a browser and see if you can reach the gateway IP. If you need help doing this, let me know what IP you obtain.
  • JDTec
    JDTec Dec 17, 2008
    yes, did you get an IP when you plugged straight into the router?
    If the Westell modem is set to "Bridge" mode, DHCP shpuld be disabled on the it. And the router should be be DHCP and give you the IP addresses.
  • JDTec
    JDTec Dec 17, 2008
    Scholar:
  • 40 Answers
As Joed said, try resetting your router. This can be done by unplugging the device and pressing in a normally small, recessed button on the very rear of the device or on the bottom, which ought to be held in for a period of 5-10 seconds.
If you are still not able to contact the router afterward, please respond so we may continue to assist you.
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
Hi! I use bellsouth dsl on my Medion desktop. Got a small Acer notebook id ike to add to the dsl network but - do not know how to do it. Can two wires (cables) run from one modem to both computrs? Can iT...
You will need to connect a router to the Westell in order to use more than one computer with your dsl. That modem will need to be put in bridge mode in order to allow it to work with the router.
Call ATT/Bellsouth support and tell them you need to setup your modem for bridge mode and connect your Linksys router.
Mar 15, 2009 | Computers & Internet
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 1 - Overview
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
Section 4 - Connections and power up
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
Section 4 - Connections and Power Up
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
Power up the network equipment in this order:
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
Open a browser session and go surfing!
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Can not setup modem:Westell 6100 to router:Linksys WRT54G
i think the best way is to describe to you the physical setup first. so you have a computer, a modem, and a router. the setup should be like this: from the walljack, the phonecable is connected to the 6100, make sure there are no micro filters connected between the walljack and the phone line because it will not allow you to connect to the dsl. from the modem, the data/internet cable at the back of it, using an ethernet cable, should be connected to the router. and at the back of the router E1 to E4, another ethernet cable is connected there and the other end of the cable is to be connected to your computer. you are right in bridging the modem, the reason for that is because both the westell 6100 and router have GUI's or Graphical User Interfaces, in short, they each have their own virtual brain. you will not have a connection if both of them have this GUI thing, so you need to bridge your westell 6100, so that the only GUI active is the routers. to bridge the modem you may need assistance from tech support of your ISP provider. assuming that's done, light status in your 6100 should have a solid DSL light. for the router, it should have lights in WAN, WLAN if you want to connect wirelessly and E1 to E4, whichever ethernet port you're using for a wired connection. you have to access the GUI of the router to make sure you have a routable WAN IP Address. As for the IP address in your computer, it should be a 192.168.x.xxx type of ip address. this is the LAN IP Address. Basically you need to have routable WAN and LAN IP Addresses to be able to connect online. you will need to configure the GUI of your router to be able to do this. for that you may need assistance from tech support of the router or if you can follow the instructions in the manual, by all means do so. the most important thing in this setup is bridging the modem.
Dec 20, 2008 | Computers & Internet
I can't get DMZ on Westell F90-610015 to work.
NEED TO FIND THE DRIVER FOR WESTELL MODEL 6100F cAN YOU HELP?
Aug 11, 2008 | Westell Wirespeed LiteLine 6100...
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Westell 6100 dsl modem
I use a Westell 6100 modem....internet goes out periodically and is not red...just blank....in a few minutes it comes back on....and later out it goes again....
Dec 02, 2007 | Westell Wirespeed LiteLine 6100...
Connect to wireless D-Link and Westell6100
I am assuming that you have a functional LAN cable connecting the Westell and the DI 524, right? If you are unsure, replace it with a cable you know is good.
If the 524 is turned on downstream of the Westell modem, it should find what it wants. You may try rebooting the Westell and seeing if the 524 finds it, and you maybe should reboot the 524.
Sometimes, when the world gets jiggered up I have to work pretty hard to get my DI-524 resync'd to my DSL modem.
Oct 26, 2007 | D-Link AirPlus DI-524 Wireless Router
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
D-Link AirPlus DI-524 Wireless Router Logo
1,991 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
