I have a Starbucks Barista (Saeco?) espresso machine that does notdispense water from the boiler. The pump and boiler do work and I candispense hot water or steam through the wand. But I can not get waterto come out where the coffee is. I have taken off the metal screen andcan see the rubber seal/gasket but I don't see anything obviouslywrong.
When I push the button to make espresso the pump runs normal for a second or so and then it sounds like it is having trouble moving the water, but if I open up the wand valve the pump easily moves water through the wand. I'm not sure if water is running back into the water container, but I don't think I head it doing that.
Is there a way to dismantle the boiler to look for blockage or seized parts?
I also ran diluted vinegar through the machine (wand) trying to break up any calcium/lime buildup but it seem to have had no effect.
Thanks, Johnny
Comments:
Dec 17, 2008
- I should also note that machine does slowly drip hot water when the espresso button is presses.
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
The little ed exclamation point light is flashing rapidly. Usual cleaning fixes, etc. are doing...
(More)
The little ed exclamation point light is flashing rapidly. Usual cleaning fixes, etc. are doing nothing. What does this signal mean?
our miele 615 coffee maker had a message that the brew unit was blocked. when we tried to remove...
(More)
our miele 615 coffee maker had a message that the brew unit was blocked. when we tried to remove the unit the brew unit was stuck. we finally removed it, cleaned it and now it won't click when we put it in. and the machine is telling us it is not in. help
