Question about Ld Asus P5LD2-VM Socket 775 Motherboard - Intel 945G Chipset - Dual Channel DDR2-400/533/667 - Onboard ... (ASUP5LD2VM)
How to connect usb sockets in the mother board itself?
Usb
  • 68 Answers
If you consult your manual you will find two sockets marked fusb1 and fusb0 or 2, you will need to coonect your front panel usb leads to these sockets
Posted on Dec 16, 2008
I cant find where do i connect power switch there no slot indecated on the board help me pls.
Hello Friends,
If you are ask mother board power option. There are two power option every mother board, one option is SMPS power and sec option is Power Jumper. SMPS two power socket indicate 24 Pin and 4 pin also same option 24 pin and 4 pin socket available in mother board. Second option is 9 pin jumper socket hear connect to HDD power, reset power, cabinet power, power LED, and +5v DC. So you open PC and see all section and solved you problem.
Thanks.
Aug 22, 2013 | Gateway Computers & Internet
While connecting web cam to computer (mother board ASUS M2N-E SLI) the message of the system Excess of throughput of USB contrller
The camera needs more power than what the USB socket can deliver - 6 watts. Since a webcam normally uses less than 0.5 watts then either the cable or or the camera itself are defective.
Time for a new one.
Jul 03, 2011 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
I have groups of vertical lines on my TV
hi,
Vertical lines will come on the flat panel tvs if the mother board or the panel itself faulty. unfortunately it can be tested only by replacing the mother board . As it is very costly will tell you to consult some one have it spares to check the same.
Before going to that just check one thing. There will be a ribbon cable connected to the mother which will go to the lcd panel. Do one thing just remove the ribbon cable from the mother board socket and re-fix it. Some time bad contacts of this cable can cause this type of problem.
Watch the following video will help you to do the same.
ok
Jun 16, 2011 | Samsung Televison & Video
Philips DAB Radio (1gb) DA1103, just put it on mac to load more songs on. Says i need to format beacuse of disk error...ah, help
There are many problems or issue about this... the only one i can say is... if you connect usb in your computer make sure that you are connecting your usb conector into the main socket of the computer.... its found at the back of the computer.... the usb socket there is connecting directly into the mother board... so its more faster and readable... if the problem exist try it in the other computer to make sure that the philips dab radio was not broken....
Feb 28, 2010 | Audio Players & Recorders
My dvd not working, the computer cann't see it
remove the dvd wire from mother board and reconnect it again and check out.if it still shows the same problem of no detection.then it might be probably two options ,either the dvd is faulty or the other problem is that in the mother board the socket where the dvd is connected that is faulty.if the dvd is faulty then replace the dvd.but if socket in mother board is faulty then resolder the socket froma pc repair center shop.
Mar 09, 2009 | Acer Computers & Internet
Hp 1210xi usb socket broken
that's on either mother board or system control board..requires a special soldering device..is it under warranty?
Jun 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Usb cable
If you are talking about something like a front usb socket that's connected inside the PC then look at this picture as an example.
http://i48.photobucket.com/albums/f217/StuartB4/9-PinCardReader.jpg
Just look on the motherboard for these connectors.
They are usually marked usb on the board.
Mar 22, 2008 | Intel Motherboard
Samsung V30, power socket broken
You can find most any Samsung parts at this url
http://www.server-parts.com/samsung/v30.htm
Mar 16, 2008 | Computers & Internet
Front usb
In case you don't have it, here is the manual for your motherboard: ftp://ftp.tyan.com/manuals/m_s2090_100.pdf Unfortunately, this motherboard does not appear to have USB headers on the motherboard itself so the only way that you can connect up the front motherboard headers is by getting an USB PCI card that has headers on it. Something simillar to this: http://www.newegg.com/Product/Product.aspx?Item=N82E16815108107
Jun 19, 2007 | Tyan Trinity S2090 Motherboard
Ld Asus P5LD2-VM Socket 775 Motherboard - Intel 945G Chipset - Dual Channel DDR2-400/533/667 - Onboard ... (ASUP5LD2VM) Logo
121 people viewed this question
Top Ld Computers & Internet Experts
David Payne
David Payne
Are you a Ld Computer and Internet Expert? Answer questions, earn points and help others
