Question about Sennheiser RS 120 Consumer Headphones
Sennheiser Wireless Headphone Stops transmitting signal
I have my headphones on with the transmitter plugged into my computer. It works for approximately 15 minutes before the transmitter stops transmitting a signal, the green light (on/off) goes blank and all i hear is a loud static sound.
  • 4 more comments
  • gwnorowski Jan 19, 2009
    Identical problem. Is there a solution?
  • gnewman313 Jan 29, 2009
    Same problem but only about 10 minutes. Unplugging from the sound source solves it each time, but only for a few minutes.
  • celuisansnom Feb 23, 2009
    same as above: works fine for 10-15 minutes then loud static.
  • flassi
    flassi Mar 03, 2013
    I have same problem but only when sound is not very loud... if I put more volume its fine... Annoing think
  • Anonymous Mar 26, 2014
    Sennhieser headphones rs110 series. Headphones work great however for no apparent reason the transmitter will power off for anywhere from 5 to 45 minutes. When it comes back on it may stay on for several hours and then simply turn itself off. When it does come back on it will stay on for 5 minutes to several hours or only 5 to 10 minutes. Any ideas from anyone would be greatly appreciated since when the trans unit goes off the static is ear shattering.
  • Joe Norman
    Joe Norman May 15, 2016
    After reading this response and another that said check the connection of the transmitter (I had tried everything else - connections, volume) I unplugged the base signal cable and simply plugged it back in AND IT WORKED. No explanation why it happened in the first place - I have no kids, no pets, I went to bed one night and it was working - turned everything on the next day and the headphones weren't working. NOW THEY WORK. Base connection wasn't loose - I jus unplugged it and plugged it in again. GOOD LUCK!!! Joe
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
    Novelist:
  • 155 Answers
Unfortunately these headphones have a “feature” that shuts them off after a set amount of time has passed. If no audio signal is detected.. after x number of minutes.. off they go.
A great feature for extending battery life.. a poor feature when using with sources that often have long pauses between signal output.. like using with a PC.. Often when listening to music while working on a document.. the music ends.. and a long pause ensues.. and the headphones turn off.
You need to turn them on and off again when you are sure an active audio signal is being sent to the base unit.
There is no workaround..
Since your problem doesn’t state they quit working during listening.. the above answer is all I have for now.
Other obvious things to check.. batteries.. and connections.. especially the connection on the base unit.
Best of luck
Posted on Apr 24, 2009
  • colt_cobery Aug 12, 2011
    This is exactly the same problem that I have right now... it was driving me crazy... well at least I know where I stand... thank you.
I can't believe anyone would design a pair of headphones with an "automatic switch off" without giving the option to turn the "automatic switch off" off.
Posted on Jun 18, 2010
    I am thinking about contacting the company if I cannot get a workaround... my wife bought two pairs of these headphones as a birthday gift to me to help me study, and the delay is an absolute nightmare... I basically have gotten that ringing in my ear about 4 times when the loud static comes on... It is insane.
  • 4 Answers
If you're using a mac, I've made an instructable on how to make this a little more bearable..
http://www.instructables.com/id/Wireless-Headphones-3-minute-transmitter-cut-off-f/
I'm sure there is a way of doing it for a pc using a batch file or something but I'm not too up on my pc programming anymore..
Hope it helps..
Rob.
Posted on Jan 18, 2011
  • dobbler31 Jan 18, 2011
    Whoa, just realised this was posted 2 years ago.. better late than never?
Sennheiser HDR120 - missing transmitter / alternative OR replacement?
The system is working in the 860 Mhz range, so not that common. Most of the time it is cheaper to by a complete new system then to tray to buy components. Just keep looking in the thrift stores you find a transmitter for this headphone for a good price.
Jun 15, 2014 | Sennheiser HDR 130 Consumer Headphones
A2dp pairing problems
The Victsing unit states that it is a receiver. This will receive the wireless signal from a device and output sound through the headphone jack. A bluetooth transmitter would input sound into the headphone jack from your tv or other source and transmit the signal over bluetooth to a paired receiver. Two of the same type of unit will not pair with each other.
May 10, 2014 | Victsing New White Black Bluetooth A2DP...
Connecting to PC
look on the pc for a headphone connection..it should have that 1/4 plud with the headphone emblem near it.. thats where the headphone wireless transmitter plugs in.. then it should work as long as your output on the pc is turned up at least to 50%
Jan 21, 2014 | Meridian Point 6 in 1 Wireless Headphones...
Sylvania wireless headphones
Instructions
Set up the transmitter. Wireless headphones rely on a transmitter that sends audio via infrared or radio waves to your headset. Use the digital audio output (coaxial or optical), RCA outputs (red and white) or headphone jack on your TV to connect the transmitter. The connection will depend upon which outputs are available on your TV and/or the transmitter.
Use an RCA-to-headphone adapter. If you don't have a headphone jack on your TV and the transmitter includes only a headphone connection, connect an RCA-to-female headphone connector. This will allow you to plug the wireless transmitter into the female headphone end and then hook the RCA ends into your television's audio outputs. You may also need a 3.5 mm (mini jack)-to-1/4-inch adapter if the headphone plug on the transmitter doesn't match the television jack.
Read more : http://www.ehow.com/how_4883556_use-wireless-headphones-tv.html
Set the transmitter on top of, or next to, the television. For infrared transmitters, you'll need a direct path between the headphones and the transmitter. Placing the transmitter on or near the TV will allow you to take advantage of the clear path you already have.
Plug in the transmitter and turn it on. Charge the headphones if necessary.
5
Turn on the headphones. Adjust the volume and settings and you're ready to watch TV.
good luck
Nov 14, 2013 | Sylvania SYL-WH930GB Wireless Headphones
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
Left headphone not working
what is the source of the audio? I would start by checking that first. switch sources to see if the transmitter is the problem if the transmitter is only getting the right side signal, that's all you'll hear...hope this helps!
Jun 13, 2012 | Sennheiser HDR 120 Consumer Headphones
Sennheiser RS126 headphones/base stopped working
Broken audio cable entering the transmitter or audio jack plug.
Power supply plug loose / faulty power supply.
Nov 10, 2017 | Sennheiser RS 120 Consumer Headphones
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Unable to listen to my wireless
They need a minimum level of signal to switch on the transmitter.
Verify if it works on yet another system.
Make sure you have the right output on your Samsung.
Try to increase the output level of your Samsung...(up the volume, but it may be a fixed output..)
Dec 02, 2007 | Sennheiser RS 110 Consumer Headphones
Wireless Headphone not working with my portable DVD player
Firstly, make sure your DVD have built-in IR wireless module so that your headphone can receive the audio signal from your DVD player.
Second, it should be clear which frequency transmitted from your DVD player. Generally speaking, there are two frequency of IR transmitter.One is 2.3MHz/2.8MHz. another is 3.2MHz/3.87MHz. Only emission frequency same as receiver can receive the audio signal.
Jul 02, 2007 | XO Vision Wireless Infrared Stereo...
Sennheiser RS 120 Consumer Headphones Logo
5,219 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Steve Allison
Steve Allison
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
