Question about Dell Dimension 3000 PC Desktop
Dell Dimension 3000 will not run OS. Cannot get into BIOS
I switched the hard drive from my old computer to a faster machine. Now the machine will not load the OS. When i tried to enter BIOS the machine had a password on BIOS. How do I reset the password?
  • 68 Answers
The manufacturer defualt password is 'dell' so you can try that. Otherwise reset the cmos chip by following the instructions in your motherboard manual. The reason it will not load is that when most os's install,. they install the neccesary drivers and software for the hardware present. Moving the harrdrive will not generally work. Your best bet is to back up all the data on your old machine to dvd etc and then format the drive and complete a re-install.
Posted on Dec 16, 2008
    Problem Solver:
  • 5 Answers
I think probably the easiest and safest method for you is remove your Windows Password with Windows Password Seeker. I found it at PC support channel last week, and then I download it from and used it to remove the lost password within 5 minutes. Besides, the helpful tool no need to reinstall Windows OS. It is worth an attempt.
Posted on Nov 03, 2011
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
Hi, I have a Dell dimension 2400 desktop. I plugged in a (wiped securely) hard drive. After it loaded the DELL LOGO BIOS, it shows a blank screen with a " dash -" on the top right corner. I...
try tapping the F12 key over and over when you see the DELL Screen to bring you to the boot menu....with your CD in choose to boot from the CD and it should allow you to run the OS installation from there.....your machine is trying to boot from the hard drive that has no OS on it.
Mar 29, 2011 | Dell Dimension 2400 PC Desktop
No Sound Dell Dimension 3000
1)Check whether sound is enabled in bios.
2)Install Latest drivers from
3) Boot From the ResourceCD to Run Dell Diagnostics
1. Insert the ResourceCD in the optical drive, and restart the computer.
2. Tap the <F12> key during startup until the One Time Boot menu appears.
Note: If the One Time Boot menu does not appear, restart the computer and try again.
3. Press the <Down Arrow> to highlight Boot from CD, and press <Enter>.
4. In the ResourceCD menu, select Run the 32 Bit Dell Diagnostics, and press <Enter>.
5. The Dell Diagnostics screen appears.
Run sound test
Jan 10, 2010 | Dell Dimension 3000 PC Desktop
My computer cannot find he primary hard drive
Hi friend,
this is not your system problem. it is your wire problem. You need to change your hard drive cable then try.
Dec 17, 2009 | Dell Dimension 3000 PC Desktop
I have 2 computers one dimension 3000 dell. on the drive is down. the other has no partions built in. is it possible to find the bios chip on the one computer, swap out to the other that has a boot...
it would probably be easier to just swap the hard drives. then when you go to boot, put in an OS install cd (Mac OS X ; Windows XP ; Windows Vista ; Windows 7) and it will walk you through the steps and partition your hard drive for you.
Oct 06, 2009 | Dell Dimension 3000 PC Desktop
Attempted to install New 320G hard drive in a Dell Dimension 3000, but the BIOs refused to see the drive at all. Despite double checking jumper settings and using other cables. The OS is Windows XP SP2,...
Check to see which bios version your computer is using. An update is probably necessary in order for the computer to detect the drive correctly.
If that doesn't work most hard drive manufacturers have software that you can install so that the bios will detect the drive correctly.
What's the make and model of the new drive?
Mar 09, 2009 | Dell Dimension 3000® Pentium® 4...
Move HD from Dimension 4300 into Dimension 4700 / XP HomeED both.
You can change the hard drive, but it will create major driver issues.
You will have to let the computer tell you which drivers are missing and go back and download them from the manufacturers website or use the software that you have.
You cannot damage the hdd doing this.
The easy way to do this would be to install this as a secondary hdd, this would allow for more storage and less problems.
Dec 30, 2008 | Dell OptiPlex GX270 PC Desktop
Dell dimension 4600
check in the bios that it is your new hardrive it is seeing, and not your old one still sitting in thr bios memory, as taking out the battery doesnt always delete the cmos memory.
There shoul be an option in the bios to auto recognise the drive
Aug 24, 2008 | Dell Dimension 4600 PC Desktop
Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Jan 26, 2007 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
616 people viewed this question
Alun Cox
