Sansa e200 My Sansa E200 was working fine with a 1 Gig Micro SD Flash drive .Now after it Refreshes the database none of the songs on the Micro SD show up in any of the menu's. I updated the player at the Sandisk web site,checked the flash drive in me PC.All the songs were present and playable. Yet when I insert the card back into my player it refreshes and the songs are still a no show..please advise... Thanks
I'm having the same problem. Some of the music that I loaded on to the micro sd does play, but if I add any new songs to th micro sd, they do not show up on the player. The songs will play if I hook the player up to my PC though.I'm having the same problem. Some of the music that I loaded on to the micro sd does play, but if I add any new songs to th micro sd, they do not show up on the player. The songs will play if I hook the player up to my PC though.
The Sansa e200-series uses microSD cards. Your 4GB card is actually a microSDHC card (the HC stands for High Capacity). While it fits into the slot, it is electronically incompatible and won't work. You need to go with microSD cards, 2GB and smaller.
You need to use microSD cards, 2GB and smaller. Your 8GB card is actually a microSDHC card (the HC stands for High Capacity). While a microSDHC card will fit into the slot, they are incompatible with the Sansa e200 series.
click on support at the top; click on MP3 players,
find your Sansa and click on it there’s a lot of info
You might want to restore to factory settings. Only problem, you will loose all the music etc in your Sansa, but it should work. First back up the media on your Sansa to your hard drive, flash drive or SD card so you can reload it more easily.
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
Dude, c'mon - you have a Linux based system - did you really think it was going to work? Just playing with you. I would check the Linux forums on this one - if you're smart enough to use Linux, then you're smart enough to grab software info from Sandisk's website/cust svc line and pass it to your Linux buddies to hack.
-Plug in your mp3 player -Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files. -Either select all your songs, open them with 'Windows Media Player' and transfer them that way. -Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder. [MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200 - verify the version of the player. To check, go to SETTINGS > INFO.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards NOTE: Firmware is not interchangeable.
It's only reading the data on the micro sd, it just has to have that little time to do that, even if there is hardly anything on the sd, it still needs to check it out, just like it does with its own drive. Don't seat it, if you don't like it see if you can put the data onto the main drive of your sansa.
mine still dose not work
