Question about Compaq Presario Notebook
I'm trying to upgrade memory in a compaq presario m2000 laptop. Was told it would be obvious and easy but looks tough to me. Can you help?
    Novelist:
  • 157 Answers
1. Save your work and close all open applications.
2. Shut down the notebook.
If you are unsure whether the notebook is off or in
hibernation, turn the notebook on and then shut it down
through the operating system.
3. Disconnect all external devices connected to the notebook.
4. Disconnect the notebook from external power.
5. Remove the battery pack.
6. Turn the notebook upside down.
7. Loosen the 2 memory compartment screws (1), and then lift
up and remove the memory compartment cover (2).
8. Remove a memory module.
To remove a memory module:
a. Pull away the retention clips on each side of the
module 1. (The module tilts upward.)
b. Grasp the edges of the module and gently pull the module
out of the memory slot 2.
c. To protect a memory module after removal, place it in an
electrostatic-safe container.
To insert a memory module:
a. Align the keyed (notched) edge of the module with the
keyed area in the memory slot 1.
If you are inserting a single memory module into a vacant
memory compartment, insert the module into the lower
slot. (The following illustration shows a memory module
being inserted into the second slot of a memory
compartment that already contains a memory module.)
b. With the module at a 45-degree angle from the surface of
the memory compartment, press the module into the
memory slot until it is seated 2.
c. Push the module downward until the retention clips snap
into place 3.
9. To close the memory compartment, align the tabs on the
memory compartment cover with the cover slots on
the notebook, and then slide the cover over the memory
compartment until it is seated 1.
10. Tighten the 2 memory compartment screws 2.
I'm trying to upgrade memory - 5c63122.pngttp://i.fixya.net/uploads/images/5c63122.png" alt="5c63122.png" class="h_mi" />
11. Replace the battery pack, reconnect the notebook to external
power, and then restart the notebook.
Hope this helps. If you need anything else, don't hesitate to ask. Also, here is the manual for your machine with more instructions. Pretty handy.
Happy Holidays!
-TJ
Posted on Dec 16, 2008
  • 928 Answers
Where are you having a problem at. When you open the back panel you will see the memory. You can follow the directions at the manual at teh link below. Click on the 4th line which is the maintenance and service guide go to page 111.
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=433559&
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
My Compaq Presario M2000 will not power up.
hi im josh in cebu phils.may i help you? Friend if that happens that it will not turn on after doing such things I suggest to remove first your DVD burner and installed back your Memory.be sure it is seated firmly in its position try to see the marking on your memory and on your mainboard.then try to reboot your pc. after rebooting if it powers on so thats the time you go back again in putting back your DVD burner. Remember dont install your DVD burner unless your pc turns on to avoid misleading. try to do it bro. good luck hope i helped you.
Feb 26, 2009 | Compaq Presario M2000 Notebook
Memory Upgrade for Compaq Pressario M2000
how to increase the performance of my PC?
would you give me the recommended brands of motherboard
that economic but good in quakity.
Sep 18, 2008 | Compaq Presario M2000 Notebook
Compaq Presario M2000 PC Notebook
The Bios on the laptop motherboard only will recognize a total of 1gig Ram. So the 256 stick would be removed and 2- 512 sticks installed.
May 22, 2008 | Compaq Presario M2000 Notebook
Upgrade ram
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
Getting a blue screen on Compaq Presario M2000 Laptop
Blue Screen of Death - BSoD Also known as a bluescreen or bugcheck in Microsoft Windows NT, 2000, and XP, BSoD is short for Blue Screen of Death and is a full blue screen error message .
MS-DOS edit command help edit c:\autoexec.bat = This would look at the autoexec.bat; However, if the file is not found, you will have a blank blue screen.
Good Luck! Read and follow instructions/Please dont for get to Vote/Thank You.
Dec 26, 2007 | Compaq Presario M2000 Notebook
Video Card up grade
ebay is always a good place to get things i just brought a new graphics card off ebay for mine!
Nov 02, 2007 | Compaq Presario M2000 Notebook
Compaq Presario Notebook Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
