This model has a wireless connection. I have a unifi wireless connection in my house but when I did the setup and keyed in the password I could not get the connection. Network status shows I am connected to the gateway but cannot connect to the DNS. Tried several times including rebooting the network modem but still no connection. Any other way to do it? Thanks
SOURCE: What brand USB Wireless Adaptor will work with my LG TV
Any brand of USB Wireless Adapter will work. Netgear, Linksys, etc
SOURCE: I have a slyvania NB620SL1
Had the exact same problem. Check your system setting on your router. See if you have a SSID broadcast check box, if it is unchecked, check it then try it.
SOURCE: I could not connect to
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
SOURCE: I cannot get the TV
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection: 1. Check the Network Connection. 1. Using the supplied remote, press the Home or Menu button. 2. Select Network Setup . 3. Select View Network Status . 4. Select Check Connection . If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection. Follow these steps, if the error continues to appear: 2. Unplug the TV and wait 60 seconds. 3. Power on and off all of the networking equipment, including the modem and router. 4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer. 5. If the issue continues, wait and try viewing the content later.
I have centuylink8561 but tablet shows locked and willnot connect it tries but show secure wep and no connection
