Question about Tomtom GO 720 GPS Receiver
Security lock enabler
When I type in an address the security lock comes on and I can't do anything and I don't know how to get it off.
  • kfinlayson Jan 04, 2009
    when I try to put in an adress the security lock appears and I don't know how to get out of it
  • 36 Answers
Main Menu > Change preferences > Safety preferences, then uncheck the box next to Hide most menu options while driving.
Posted on Dec 22, 2008
Lock my d-link
You can access the router through web interface and configure it.
The default username is admin and leave the the password field blank - Don't type anything - and Click Login). All you have to do is connect the router to the DSL Modem through LAN cable (or wirelessly) and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and leave the the password field blank - Don't type anything)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
You may refer to Product Manual (Page47 onwards for security settings)
Feel free to contact me for further assistance
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 27, 2011 | D-Link DIR-615 Wireless Router
I purchased a new laptop,,and when Itried to connect to the internet wirelessly it recognized my router, but asked for security code. I don,t know what my code is.
if you don't know your security code, then you will need to reset the router (Use the reset button on the back) then you should be able to connect wireless unsecured. from that point you can type the default gateway IP address (192.168.1.1) in the address line of internet explorer, this will open the web interface of the router (Leave username blank, admin for password) then you can re-enable wireless security and pick a new code (I recommend an old 10 digit phone number you can easily remember but hard for others to guess)
Sep 25, 2010 | Linksys Wireless-G WRT54G Router
Hi, I bought Asus Wireless Router RT-N13U. I notice that there was no entry of password for security, which means anybody (even neighbors) can access this router? Did I miss anything during the setup? How...
You need to enable WEP or WPA or WAP in wireless security. For that access your wireless router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then enable WEP security enter Password then apply and save settings then restart router . Then only those can connect who know that password. . Let me know if you need further assistance. Thanks for using FixYa.
Aug 09, 2010 | ASUS Computers & Internet
How do i secure my belikn from outsiders using it
Enable wireless security on your router, so that other people will not be able to connect to your network.
To enable wireless security, access the setup page of the router through a web browser. Type 192.168.2.1 in the address bar.
By default, leave the password blank.
Once in the setup page, go to Wireless. Take note of your SSID. Then go to Security.
Select WEP or WPA, depending on the operating system and capabilities of your wireless computer. If in doubt, you may use WEP since it is the legacy wireless standard.
You can enter your WEP key manually by typing in the hex WEP key manually, or you can type a passphrase in the “PassPhrase” field and click “Generate” to create a WEP key from the passphrase.
Make sure to take note of the WEP key because you will be needing this for your wireless computer.
Click Apply Changes.
On your wireless computer, view the available wireless networks, select your SSID, then type the WEP key.
I hope this helps!
May 11, 2010 | Belkin (F5D9230-4) Wireless Router...
How do I password protect my wireless router?
go to start> run> type "cmd" > the command prompt window opens up.... typr "ipconfig" in command prompt window.... note down the default gateway address below ethernet adapter local area connection... type the default gateway address(usually 192.168.2.1 for belkin routers) you ll login to the router page.... now search for the option like "security" below wireless... enable security to 64 bit WEP and enter a 10 digit number as a password in key 1....donot type anything in any other boxes....click apply changes...thats it....your network is secured....now goto your computer and delete all preferred wireless networks and scan and connect the secured network...it ll ask for the security key...enter the key and get connected....
Mar 30, 2010 | Computers & Internet
Securing my wifi network
Hi George,
Simply open your Internet browser, in the address line, inset 192.168.0.1, then:
-> Goto TOOLS
Here you set the administrator password, note that you have to set the same password twice.
Do set some security as well, other vice your neighbor will use your network, - and that you don’t want, as you don’t know what and where he go on the internet.
On page 27 in your manual, you find the way to set the wireless settings.
On page 37 in your manual, you find a way to set MAC address settings. Thise settings allow only those MAC addresses as you put in the table.
You find your own MAC address like this:
->Start->run->write cmd and hit enter; a black DOS window open, write ipconfig /all (note the space before /all). Here you find your MAC address – note that there is two cards in your laptop, and the card you want the MAC address for is the wireless card.
regards
Teis
plz let me know if you need furter help.
Jan 17, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
How do I security enable my Belkin router?
Connect a computer to any one of the four LAN ports of the Belkin wireless router. DO NOT use a wireless connection, use a cable.
Open your web browser and type the IP address of the router (by default, the address is http://192.168.2.1.) in the address bar and press Enter.
Click Login on the top of the page to login to the router. By default the Password is left blank, click Submit.
Click Security under Wireless menu.
Under Security, Select 64 bit WEP (or 128 bit WEP).
Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength). You may also enter a pass phrase and have the router generate a key for you. Example (0102030405060708090a0b0c)
Apply the settings.
Please write down the key – You will need it later to configure your wireless computers with the same key.
Remember to set an admin password before you close down, other vice anyone can access you router and change the setup and admin password.
/regards
Teis
Jan 01, 2009 | Belkin (F5D6230-3) Wireless Router
I have a problem cause I bought a router and I want change my security key. I have a WEP security key but i want have a WPA. But i dont know how to change. What should i do?
type 192.168.0.1
on your address bar.
Look for anything that says "Wireless" or "Wireless Settings".
Under Security or Encryption setting, change the value to WPA.
Save your settings
Note: your password for the wireless will be the same, but your WIRELESS computers will look like they are disconnected. Just reconnect them by connecting to the router and typing in the password again.
If you cannot view this page,
type http://www.routerlogin.com/CA_HiddenPage.htm
Select: Disable Configuration Assistant, and click on Apply.
You can re-enable it by navigating to
http://192.168.0.1/CA_HiddenPage.htm (where 192.168.0.1 is your router’s IP address)
Aug 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
How do I go about securing my home network. I use Belkin G Plus NIMO.
Open a browser window and in the address bar type 192.168.1.1 or 192.168.2.1 and this will open the router page. Navigate to the security and enable whatever security level you require. Hope this is a help. Let me know if there is anything else.
Aug 22, 2008 | Belkin Computers & Internet
Tomtom GO 720 GPS Receiver Logo
526 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
