Question about Sharp AL-1000 Laser Printer
Horizontal lines appearing at the top of print
We have a sharp MX 6200 printer.
When printing a black print on heavy paper black horizontal lines start to appear after a while. We have tried othe black jobs and colour the problem only arises with this particular job set at A4 heavy paper 1 or 2 from any tray. If you run another job the problem will clear for a while but always returns.
Any advice appreciated
Bubbabear64
  • 2794 Answers
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Posted on Jul 20, 2008
SOURCE: Jobs going to Sharp MX-C311, but printer not
Worked with Sharp Support- client was using accounting and passcode was not set
Posted on Jan 21, 2010
  • 33 Answers
SOURCE: Our printer is printing horizontal lines across
open the front door and press the green button in the center upper ,remove the waste toner collector ( carefully it will spill if turned over ) you will see four green knobs small diameter these are cleaning rods ..pull them out about a foot they will stop push them back in four or five times each color there is also a wand on the door and it fits pad down in the slot below the green rods slide it in and out to clean the laser....if this does not do the trick you will need service refr to you manual for cleaning if you have it
Posted on Jul 20, 2010
  • 8 Answers
SOURCE: A horizontal line is appearing on our prints and
What color is the line? This is usually caused by either dirty primaries or drum units. Laser units or dirt on them can cause the same issue. On the door of the copier is an instrument to clean your laser cover. Make sure you consult the manual on how to do this. If it is even possible to do it incorrectly you could cause incredible expense in repair costs. The manual for this copier can be found very easily especially on sharp's website. The only way to clean the primaries is to take the drum unit apart. Should be done by technician.
Posted on Aug 17, 2010
InPlainEnglish
  • 137 Answers
SOURCE: I use my Sharp AR-BC320 as a network printer, how
  1. Click <Start>, <Contol Panel>, (in Windows 7) under Network and Internet <View devices and Printers>.
  2. Right Click your Printer, Select <Printer Preferences>
  3. Choose the <Features> TAB
  4. Under Color Options Select <Print in Grayscale>
  5. Beneath the Print in Grayscale is a Dropdown box, Select <Black Ink Only>
Thank You For Choosing FixYa~!
Posted on Mar 18, 2011
My IR2520 printer keeps printing papers with black horizontal lines everytime i replace the drum unit and the toner it works for only two weeks and again the same problem appears...
take printer outside of building and use a can of compressed air to blow any split toner out of toner cartridges area and from the insides of printer and around the rollers for the paper.
Compressed air can can be purchased from electronic hobbyist type stores. Had same problem with a laser printer and this was how I fixed it . Check toner cartridge is not leaking toner also .
Nov 22, 2017 | The Office Equipment & Supplies
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Sharp AL-1000 Laser Printer Logo
44 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
