Question about Dryers
My dryer overflows everywhere with lint each time I dry a load.
I clean it every time, and have had the flexible vent professionally cleaned out, no change
  • 3,463 Answers
I suspect that there is a blockage inside the dryer, and the lint is not getting through.
With the vent hose removed, you should be able to feel a good blast of air coming out of the back where the hose fits.,
Plz leave feed back for this solution.
Thanks.
Posted on Dec 16, 2008
Whirlpool ggw9250pl3
Sounds like an airflow issue. You should remove the dryer vent hose and see if the exit of the dryer is plugged up with lint. If so you should have the dryer cleaned AND the dryer vent line exiting the home. This is one of the biggest contributors to house fires. Have your dryer vent professionally cleaned.
Feb 12, 2017 | Whirlpool Dryers
Tip
Clean Your Dryer Vent to Prevent Fires
Most people have no idea how much lint gets past your dryer's lint trap. The amount is substantial. Over Time your dryer vent pipe becomes coated with dryer lint. If your dryer vent hasn't been cleaned in over a year, you may have a potential fire hazard on your hands. Once the vent becomes restricted your dryer will take longer to dry a load. Lack of airflow will cause your dryer to over heat. If your dryer vent is over eight feet long, your dryer vent should be cleaned annually. Some of the early warning signs of lint blockage include:
  • Is the top of your dryer hot to the touch?
  • Does your dryer take over 50 minutes to dry a load?
  • Do you ever experience a moldy smell on your clothing?
  • Is dryer lint gathering on the inside of the dryer door?
  • Does it seem like your clothes have extra lint on them?
  • Is your house dusty? Dryer lint is almost microscopic and goes everywhere.
Most dryer vents have a flap or a screen located at the exit. This must be cleaned on aregular basis. Where your dryer vent exit's the building is usually the first place dryer lint will gather. It is very important when you have your vent cleaned they address the exit.
Dryer vents come in all different shapes and sizes. The dryer vent itself refers to the exhaust pipe inside the wall. This pipe should be a 4" steel pipe that exits right outside or some times up through the rooftop. Some builder's occasionally use the more rectangular gutter piping, or the flexible metal piping. Both of these can be inefficient. If your home has a foil accordion type material inside your wall, this needs to be replaced immediately. This material is actually flammable, if you ever had a dryer fire it would have no chance of staying contained.
A dryer vent that exits on to a tile roof can pose another potential airflow restriction. Much of the time builders use the same gooseneck type exit as on a standard shingle roof. Unfortunately these vents aren't long enough, and tend to vent right on the tile with very little space. The fix for this problem is to fabricate an extension that raises the vent at least four inches above the tile.
Another common problem is a crushed transition tube. The transition tube is the pipe that connects the dryer to the wall vent. Most of the time delivery people use the foil type transitions because of ease of installation. Unfortunately this material can easily become crushed or restricted. This type of material is actually paper and can ignite. Unlike the all metal venting material that the dryer manufacturers recommend this material is a real fire hazard. (see your owner's manual or the labels on back of the dryer.)
Unfortunately a blocked dryer vent can break your dryer. The two main parts that break, are the element and the thermostat. The excessive heat produced by a blocked vent is a repair waiting to happen. Many of the new high efficiency dryers have warning lights that tell you when your vent needs cleaning. Some of these dryers even lower the temp on their own to keep from overheating.
The best way to test your dryer vent's efficiency is to disconnect the tube from the wall and dry a load of clothes. If your clothes get dry in a reasonable time it's your dryer vent. Over 15,000 dryer related fires occur every year. Most of these fires could have been prevented, with an annual vent cleaning. Don't become a statistic get your dryer vent professionally cleaned today.
on Jun 07, 2011 | Dryers
No heat in drum heat out of vent maytag mle2000ayw
Are you sure you dont need a professional Dry Vent inspection and cleaning?
If you are in the market for an Dryer Vent cleaning check out Dryer Vent Cleaning Dallas Tx.
Mar 17, 2013 | Maytag Neptune Dryers
Maytag dryer will not restart immediately after drying a load. has to cool down
try cleaning out your dryer vent. Remove your lint trap and use a flexible wire brush to clean deep inside, then remove your dryer vent hose and make sure all lint is clean from the dryer side of the vent and the vent hose all the way to the out side vent.
Sounds like it may be clogged with a build up of lint
May 23, 2012 | Dryers
We have a combo dryer and washer. Washer is A2444330KH. Leaves lint on cotton shirts, have cleaned the filter no help. Any ideas? David
Dryer lint not only presents a problem by cluttering up your clothes with white specks, but it can also lead to a dryer fire. While it is impossible to completely eliminate dryer lint, you can take action to drastically reduce lint and the potential problems that come along with excess dryer lint. If your clothes take more than one cycle to dry, you see no lint on the lint screen, the clothes are very hot after drying or you find excess lint on the clothes after drying, you probably have a problem with accumulation of dryer lint in the dryer vent.
Use a dryer vent cleaning brush and clean the dryer vent, or hire a professional to clean the exhaust vent behind your dryer. If your dryer vent is clogged, it will create excess dust in the dryer and on the clothes. The excess lint can eventually catch on fire given the heat load of the dryer.
Dec 05, 2010 | Maytag Washing Machines
I have a Frigidaire stackable full-size washer/dryer. I don't have the model number, but it is about eight years old. The dryer does not get hot enough to dry even a small load well.
When was the last time you cleaned out your vent? It should be done every 1-2 years to prevent build-up of lint and possible blockage. Also make sure your outside dryer vent flap is not stuck closed or clogged. I use a plumbers snake to twist inside the vent and clean out the lint. It makes a huge difference in drying time. Also disconnect the vent from behind the dryer and check for lint build-up inside the back of the dryer itself. (Be sure to unplug the dryer before you do this!) When you push the dryer back, be careful not to squish or pinch the dryer vent if it is a flexible foil or plastic tube. These are the easy fix-it's. Try them first before resorting to more expensive trouble shooting. Douglas
Sep 06, 2010 | Frigidaire Dryers
Whirlpool model # lgr7646ez3
Here are a list of causes that may contribute to this lack of sufficient drying.
CAUSE
• Lint screen is clogged with lint.
• Restricted air movement.
Exhaust vent or outside
exhaust hood is clogged with
lint.
• Exhaust vent is crushed or
kinked.
• One fuse is blown or circuit
breaker is tripped. The dryer
will appear to operate, but you
will not get any heat.
• Cycle Control knob or temperature
selector is set on air dry.
• Load not contacting the sensor
strips and automatic cycle
ending early.
• Fabric softener sheets blocking
exhaust grill.
• Dryer located in room with
temperature below 45ºF (7ºC).
• Large amount of moisture in
the load.
• Cold rinse water used.
• Load too large and bulky to
dry quickly.
Here are the solutions to combat the issues.
SOLUTION
• Clean lint screen.
• Run dryer for 5-10 minutes. Hold hand under
outside exhaust hood to check air movement. If you
do not feel air moving, clean exhaust system of lint
or replace exhaust vent with heavy metal or flexible
metal vent.
• Replace with heavy metal or flexible metal vent
• Replace fuse or reset breaker.
• Select the right cycle and temperature for the types
of garments being dried.
• Level dryer.
• Use only one softener sheet per load and only use
it once.
• Move dryer to a location with temperatures above
45ºF (7ºC).
• Expect longer dry times with items that hold more
moisture (cottons).
• Expect longer dry times.
• Separate load to tumble freely.
This will help you fix this problem. i suspect an exhaust obstruction.
Mar 11, 2009 | Whirlpool LGR7646E Dryer
It takes three cycles to dry clothes, andthere is heat?
The most likely cause is poor airflow. This may be due to a clogged lint screen (should be cleaned after each load) or a clogged vent. Run the dryer empty and feel the airflow from the vent outlet (where the vent exits the house). If there isn't a good strong flow of air, remove the duct where it attaches to the dryer and check for flow right at the dryer. If there still isn't good flow you may have a bad blower, but chances are the duct is clogged with lint. If it's the white plastic flexible duct or the corrugated metal kind you should replace it with solid 4-inch vent pipe. This will give the best airflow and the smooth walls won't promote lint buildup.
Jan 26, 2009 | Kenmore 22422 Top Load Washer
Maytag Gas Dryer - Shuts off before clothes are dry - was cleaned ?
check to make sure no "dust bunnies" got inside you vent hose blocking air flow.
Oct 30, 2008 | Whirlpool LER4634J Electric Dryer
I want to know how to remove the lint trap (not just the screen but the entire assembly) from a Maytag Performa PYET344AZW front loading electric dryer. The lint screen will not even properly slide back...
Besides drying clothes, dryers also remove lint. This fine, fuzzy material can cause trouble because it blocks dryer lint traps, clogs vents, and fills blowers. Lint can also gather around and in the tracks of the drum rollers, or in and under the pulleys and the drive belt. The result is poor clothes drying or -- sometimes -- no drying. To avoid lint problems, clean out the dryer's lint trap system every time you use the dryer.
To clean the lint screen, remove it from the unit. The screen may be located near or under the door sill, or in the top of the dryer near the control panel. It can usually be removed by pulling it up and out of its housing. Remove the accumulated lint to clear the screen; then replace the screen.
The exhaust vent also collects lint. Vent maintenance involves cleaning the lint from a screen in the dryer's vent exhaust collar and/or at the end of the exhaust vent where it sticks out through a basement window or through an exterior wall. To clean the screen, remove the clamp that holds the vent to the collar, or back out the screws that hold the vent to the collar, or pull the vent straight off an extended collar. Clean the screen thoroughly and replace it in the vent assembly.
To clean the vent itself, use a vent-cleaning brush (available at hardware stores) to pull out any lint deposits. Also check the vent run to make sure that the vent piping or tubing isn't loose at the joints, or -- in the case of flexible plastic venting -- isn't sagging between hanging brackets. Breaks or sags cause undue strain on the dryer's blower system, and can cause drying problems. If the vent pipe or tubing has become clogged with lint, remove the lint by pushing a garden hose or a drain-and-trap auger through the vent to a convenient joint. Disassemble the joint to remove the debris. With this procedure, it isn't necessary to disassemble the entire vent to find the blockage.You can head off problems before they become too serious by providing routine maintenance for your dryer's door gasket, thermostat, timer, and other frequently used parts. Let's discuss how to service these important components in the next section.
how-to-repair-a-dryer-1.jpgTHANK U.. RATE IT...
Sep 11, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
Marvin
Marvin
