Hi all, I have problem with my TV. Yesterday worked fine, turn off at 3:00 PM and 6:00 PM cant power on - 4 red blinking. I search this problem and only "power board" found. I need power scheme or better explanation of the fault. Sorry for my bad english and THX for all reply and solutions.
Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Blinking codes and fault finding proceedings to Panaos0nic TVssare described there in detail.
SOURCE: My Philips 32PFL5403D LCD TV does not turn on and blinks 6
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. I don't have the Service Manual on hand for your model number to tell you what the code means.
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
SOURCE: Samsung LN46A550 LCD power on/off problem again.
It is the Main A/V board that is faulty, not the power supply. The rainbow screen that you are seeing and the searching for signal message before it shuts off confirms this. It is the large board at the center of the tv. If you can get me the part number off it, I can find you the replacement. It will be either printed on the board itself or on a small label.
Sai.
SOURCE: I HAVE A 50' PHILIPS
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Testimonial: "THANK YOU I WILL GET BACK WITH YOU AS SOON AS I TRY THIS"
model is TX-L42S10E
thx for reply...but my model cant search
