Question about Norelco 7886XL Electric Shaver
I have a Norelco 6885XL electric razor that won't hold a charge. It will "recharge" to 44 minutes, but once below 39 minutes left it goes to 0 when turned on.
  • 1 more comment
  • jlgvh Jan 07, 2009
    I have the same problem. Can the battery be replaced?
  • Anonymous Feb 15, 2009
    Where can I mail this to in order to get it fix. Please let me know thanks
  • Anonymous May 03, 2009
    I have had the same problem with the Norelco Microflex R-9200.
  • 3 Answers
It's easy - I replaced mine (Norelco 6885XL) with a soldering iron & batteries I found online. Here's one place that sells them:
http://www.electricshaverstore.com/get_list_145.htm
As these are NiCd, I always drain them totally dead, then recharge, as this type of battery does suffer from the "memory effect".
Dave
Posted on Jan 31, 2009
  • 4 Answers
Call Norelco at:
1-800-243-3050
If under 1 year old the warranty may replace it for free.
Posted on Mar 02, 2009
Norelco 4805 xl razor won't turn on when plugged in nor will the battery charge. i would think it was the battery but it does't want to turn on when plugged in either. is the motor shot? thanks
When the battery goes completely bad, the shaver will not work even from the cord.
You will need to open the shaver and make sure that the batteries have not corroded badly and damaged the inside of the shaver.
You will find the correct replacement battery offered at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
You will also find a video tutorial on this page to halp show you how to open the shaver. See link below for another video with additional installation tips
http://www.shaveroutlet.com/shaver_battery_replacement
Jun 10, 2011 | Norelco Micro Action Shaver 4805XL...
My rechargeable razor seems to be losing its charge quickly these days. Is is cheaper to replace the battery, or buy a new razor?
You will find the correct battery for model 7800XLCC at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you prefer to shop for another shaver to replace the one you have, you will find the entire selection of Norelco shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/rotary-shavers.html?manufacturer=4
Jan 07, 2011 | Norelco 7800XLCC Electric Shaver
Arcitec razor 1050X will not cut whiskers reagardless of length, weather I shave every day or wait a few days. I must resort to using a twenty year old Norelco with old heads that still shaves much better...
You are certainly not th first person who hasn't been happy with the Arcitec model. If it never worked well for you from the beginning, there is nothing that will make it work now. It's a shame that you've waited past the 45 day return period.
Your old shaver, 6885XL, was a "Quadra" model. These were a popular model type that is now discontinued. If you still have it, it may be able to be repaired. If you would like to replace it with another Quadr model, you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shavers/norelco-7886xl-quadra-action-shaver-factory-refurbished-p-534.html
This model is virtually identical to your 6885XL except that it is a newer version
Oct 12, 2010 | Norelco Arcitec Electric Shaver -...
Norelco shaver sudden power loss
I hope you are observing the following:- Recharging only when the batteries are almost completely empty. Continuously recharging or continuously using as a corded razor will reduce life of batteries Charge only when the indicator in charge meter starts blinking. It appears that your batteries are gone. Hope you have replaced the batteries with the new ones. Use a good brand
May 14, 2010 | Norelco Quadra 7885 XL Electric Shaver
I no longer have the owners manual. What does it
According to the manual, the red light comes on while charging when the battery does not yet have enough charge to sustain a 3-5 minute shave. The green light stays on steady while the razor is charging, and blinks when it is fully charged. If your battery life is short, they might need to be changed.
Jul 14, 2009 | Norelco Rechargeable Cordless Men's Razor...
Norelco model 5885 XL Battery replacments
I just installed two brand new Eneloop cells and it will only charge up to 35 minutes on the display (I had been able to get up to 52 minutes with the original NI-CAD's). I also discovered that it would not recognize the capactiy on the minute meter until I drained the batteries and recharged the unit. When I went to drain the batteries they ran for 2 hours and 15 minutes!!! But again the display only shows 35 minutes right now after an hour charge when it says FULL. I'll leave it on the charger and see what happens. I used a pair of needle nose pliers and "rolled" the metal tabs off the NI-CAD's. Snapped the one on the negative side but got the positive side off clean. I couldn't get the strips to solder back to the new Eneloop batteries so I had to use electrical tape which seems to be holding fine. The battery holder holds the positive and negative terminals against the old tabs just fine. Also I learned that if you hold the power button on long enough it will cycle through a test function. It will go to zero minutes and all the way up to 35, then turn on and go back to zero stopping at the appropriate cleaning cycle times (takes about 40 seconds to do the test so don't touch the power button until it's done). Not sure if the batteries will still go 2 hours and 15 minutes after being charged in the shaver, but they do when chaqrged outside the shaver. Just my two cents!
Mar 23, 2008 | Norelco Reflex Shaver 5885XL Electric...
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Norelco 7886XL Electric Shaver Logo
1,777 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
