Question about Motorola Mobility E310 i285 Headset Headset
Jackie levitt when i try to download it said cannot complete transaction this transaction cannot be completed entering a nonsecure area .ok i talk to boost and he tryed to reset my phone and it did work help
0 characters
1 Points
My talk button wont let me answer or hang up
try the red button instead. or flip it shut. to end calls, i mean.
Is there a regular OK or enter button on your phone? if the green one doesnt work, try one of those to answer it.
Jul 20, 2012 | Motorola Mobility ELITE SLIVER Bluetooth...
How to get your ge ear piece to connect
How do I link my GE Bluetooth in ear style headset, model 86707 or 86710?
Answer :
Turn on the mobile phone and place within 10 ft of the headset.
With the headset turned off, press and hold the Talk button for about 7 seconds. You will hear a "pair" tone and the LEDs will flash continually to indicate the headset has entered into pairing mode.
Release the Talk button. The headset is now is "pairing" mode.
Initiate the device discovery feature (Bluetooth discovery) on the mobile phone. Refer to your mobile phone manual for further instructions.
When prompted by the phone, enter the headset passkey (0000). When pairing is complete the LEDs on headset will flash at 3 second intervals and the headset will be placed in standby mode, ready to make and receive calls.
Note: On some mobile phones you will need to activate the Bluetooth feature first and then search for the Bluetooth device. Please contact your cell phone manufacturer or the User's Manual for further information on how to pair pair Bluetooth devices.
Click to view the instruction manual for:
on Feb 28, 2008 | GE Bluetooth In-ear Headset Wireless...
Datel game talk pro 2
i had the same problem with both datel heasets.
i managed to fix that problem by opening it up and replacing the internal battery with a battery from a samsung phone lol.
but now my voice sounds crackely aparently
Jul 04, 2012 | Datel Game Talk Pro-2 Gaming Headphones...
Cant connect vwith my nokia e71 phone
hello,please kindly put your nokia bluetooth on and also power the bluetooth headset on so as to pair them. the bluetooth headset with your nokia then you might be asked to enter a code,you then enter 0000 and ok it. 2.when the pairing is complete your bluetooth headset displays and blinks red light.
wish you good luck.
take care.
Jul 19, 2011 | Nokia BH-503 Bluetooth Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
What is the pass codeto connect to the ps3
From the manufacturer's site at
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: “Register completed”
Feb 22, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I can't connect my EnV2 to my Jabra Bluetooth. Is there a trick?
It could as easy as updating your phone by dailing *228 with a Verizon phone, select option 2 then press ok when the update is complete. When the phone resets, turn on the bluetooth headset, a prompt on the phone should come up to enter the passkey which should be 0000
Sep 01, 2009 | Motorola Mobility H500 Wireless Headset
Motorola N136 bluetooth wth Palm Centro
ok, so yeah, go to your phone and tell it to search for devices. while it searches, hold down the big button on the front of the headset until the light lights up. while it's lit up, turn it on by folding out the microphone piece. this should almost instantly pair your headset.
Sep 15, 2008 | Motorola Mobility HS850 Consumer Headset
Plantronics 220 blue tooth
Another bang bang solution...
Be sure to charge your headset for atleast 15-25 minutes minimum to get a starting charge. This will also give you 15-30 minutes of talk time to test out your headset and placement, and also get used to being a part of the bluetooth generation.
Once charged, press the call button(the big button on the side) and hold it down until you see a flashing red/blue combination of lights, now you only have 2 minutes to set this up, or you have to start over.
Once the lights are flashing on the headset, it is searching for a phone, now you go to your phone, and find your options for connectivity or bluetooth, once in your menu, look for the option to search or connect to a blue tooth device. Let it search/connect automatically.
Once it is connected, the flashing lights on your headset should stop, finish the connect process on your phone, if it says found it, install it, entering device data, etc etc, follow everything it says by entering YES, hitting OK, or CONTINUE.
Once it says CODE or PASSWORD to enter for your bluetooth device, enter 0000 .Which is ZERO ZERO ZERO ZERO and then press enter.
It should take 2-10 seconds for the password to initiate, record into your phone, and pair your device. This is a detailed explanation. Please rate me for my effort.
Dec 31, 2007 | Plantronics - Bluetooth Headset Plus Base...
Pairing blkberry w/ h700
Hold down the call from an off position until the button lights up in purple color. Flips open the microphone boom. The purple light stays on. Click OK to start the pairing with Blackberry Pearl. When asked for passkey, key in 4 zeroes then press enter. Pairing should be complete from this point.
Oct 09, 2007 | Motorola Mobility H700 Wireless Headset
Headsets Logo
14 people viewed this question
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
