Question about Philips AZ1515 Cassette/CD Boombox
Boombox not used for several months. Pulled out to use. There is a humming in the background when playing tape deck but no humming when playing CD. I unplugged power cord and tried playing on batteries. Plays fine, no humming on batteries. I changed tapes and CD problem still exists when using power cord on tape deck.
3 Suggested Answers
ongolo
  • 11 Answers
SOURCE: Boombox won't play most CDs
Hi there , heres a simple case of the recording format on the cds , its likely that your daughter's cds are recorded on a computer in a format probably mp3 or higher speed thats not compartible with your boom box . The solution to this is to record your cds in Normal format , and they will surely play !
Posted on Mar 29, 2007
  • 4234 Answers
SOURCE: tape decks quit working (turning)
There are a couple of belts inside this unit that most likely need to be replaced. Unfortunately this is not the easiest unit in terms of access. I would not suggest an attempt to replace the belts yourself if you have no experience with that sort of thing. The belts should not cost more than $10 total. Check in your area for a service shop that handles audio gear. The total repair cost for this should not exceed $75.
Dan
Posted on Feb 17, 2009
Sony tc k670
Take out the tape and press play, do the wheels move? if not the motor has burnt out, the tapes may have been sticky. Hold a tape and wind the wheels with your finger, are they difficult to move?
Dec 21, 2013 | Audio Players & Recorders
Tape deck on Panasonic RX-DT680 boombox issue
I think this should be a simple fix! The deck will have switches at the top of the cassette compartment. These detect the tape and also select it for type - metal or chrome etc. These switches have become bent or damaged or have dirt on them.
May 18, 2013 | Audio Players & Recorders
How do I get it to record a voice?
Many portable 'boombox' recorders do not include a microphone for recording ambient sound, but can only record from one internal source to another, like radio or CD to Cassettte. Some do include an input jack for microphones or other audio sources, but you'll need to check your device's specs/ports to be sure.
May 18, 2011 | Sony CFD-F10 Radio/Cassette/CD Boombox
Technics M14 cassette deck has hum. Bought used and had hum but I got it to go away by switching the tape select dial to metal,etc. but hum came back later. I'm thinking ground or a wire to that switch. ...
If the hum is audible without monitoring a tape playback it has nothing to do with the oxide formulation or any aspect of the media.
Determine the conditions present whenever the hum is present:
Player just turned ON?
Tape deck Playing or Paused?
Tape deck Recording or Paused?
"Tape" selected at the receiver?
Any source selected?
What switch are you referring to? You could have a floating ground or shield through a Tape Monitor or other control. Audio cables between the Deck and the receiver could be faulty or require reseating with a twisting motiuon to remove oxide build-up.
Hum can enter any unshielded cable running near any motor, magnetic field or some light sources. Sometimes simply reversing the polarity of an AC power cord will cure it.
Feb 02, 2011 | Yamaha KX-393 Cassette Deck Dual Cassette...
The tape plays songs so fast sounds like donald duck. The speed the tape is feeding is to fast.
Hi, the casette deck has a mechanical system (servo-driver) most of the problems that happen when in your case, plays song so fast is that you look at the pinch roller. The pinch roller is a rubberized free spinning wheel typically used to press magnetic tape against a capstan shaft in order to create friction necessary to drive the tape along the magnetic heads with a normal tape speed if the pinch roller brakes, get lost from his place or got dirty then you get this fast sounds play, check the pinch roller if still good in his place or clean his rubber with alcohol, then the problem should be fixed.
Jan 29, 2011 | Sony CD Radio Cassette Boombox, CFD-E90...
Tape Deck
This unit has 2 belts that are slipping and need to be replaced. This is not the easiest repair for a novice. The belts shouldn't cost more than about $5 total. I woud recommend that you seek a shop that repairs audio gear and inquire about the repair cost.
Dan
Mar 25, 2009 | Sony CFD-G35 Cassette/CD Boombox
Tape decks quit working (turning)
Dan
Feb 07, 2009 | Philips AZ2785 Cassette/CD Boombox
Eats my Cassette Tapes
Ok sound like the play head is out of a-line ment - easy way to fix if it is this - remove from the mains supply and open the cassette deck door - press the play button down and look at the play head there is 2 screws 1 either side 1 is fixed and 1 is sprung - now inset batterys (much safer) - try and fit a cassette in without using the cassette door should just fit in then press play and ajust the Right hand side scree with a small screwdriver (insulated) and ajust slightly to the left or to the right and this should fix the chewing - to get it just right use headphones ajusting left to right will tke the sound + & - to each earphone. Warning dont turn to far to the left as this will undo the screw completely - u have a least 1 whole turn either way is fine
Nov 20, 2008 | TruTech T350B Boombox
Philips AZ1515 Cassette/CD Boombox Logo
24 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
