Question about Forfex FX 684 Hair Trimmer
The coard onthe clippers is off some how . certain ways you hold them they cut and others they dont . any suggestions.
0 characters
1 Points
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers ยท 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Shavers
Wahl clippers
The clipper was being held at too sharp of an angle
Oct 01, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Hi I have a Wahl Super Trimmer model 1591/1592 1.2V. Have had it 3 months, It doesn't cut hair anymore and appears blunt! But yet it still easily cuts paper etc. I also can get inside it as it has been...
What are you doing trying it on paper! Never cut anything other than human hair with them or they ill go dull. Keep them clean with a small brush you brush out all the hair and use clipper oil after every use. If they have been dropped * even just a little bit " it sets them off and they wont cut. Go to a salon ask them who sharpens there tools and get there info and have them sharpened you dont need another clipper. and oil after every use with clipper oil no other kind!
Nov 22, 2010 | Shavers
How do I adjust the blades or sharpen blades on a Andis T-Outliner trimmer? I have some older blades that work farely better then my newer blades that are dull if you ask me. Is there some way to manuver...
Clipper blade sharpeners are availale but the cost of these typically start at about $300 and go as high as several thousand dollars. This makes it unaffordable for home use.
For affordable, professional clipper blade sharpening, I suggest you contact the folks at
Your clipper moves at just one speed. There is no way to 'speed it up' if it is working correctly.
Feb 05, 2010 | Andis 04710 Beard Trimmer
It keeps geting hot every time i cut my hair
you should put clipper oil where the blade contacts it's base (near the middle of the base) and spray kool lube or a similar product on the cutting edge.
Aug 08, 2009 | Andis T-Outliner Hair Trimmer
Cleaning Oster 78004-011 Clippers and blades
OK compressed air is perfect for your clipper, thats all it needs! Take the filters off (at the bottome of the clipper, either side of the cable) periodically and clear from excess fur. Replace. As far as the blades are concerened, Brush the excess furr off with a toothbrush or similar. Slide the cutter (smaller of the 2 blades) to one side (past half way but not all the way off!) clean exposed teeth on both blades with a bit of oil and a toothbrush, push the cutter the other way and repeat. Blade wash's tend to rust the blades, you need a big pot of WD-40. Get a 5 litre tub from the internet, only thing is there, postage will be a killer. I work for a clipper repair, blade sharpening company and we have it delivered by the truckload! Do what you do with the blade wash, but do it in WD-40. Wipe off excess afterwards and dont soak the clipper in any liquid because of electrc shock.
Thats all you can do! When your blades go blunt or clipper needs service repair: If I have helped you please tell your friends about our website! Thank you!
Feb 25, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 keep turning themselves off whilst I'm clipping
Ok turn your clipper on and hold it still in one hand whilst with the other hold the cable near the end of the clipper and bend it, rotate and twist if your clipper cuts in and out you have a break in the cable which is tricky to fit but our web site Help section can help.
Feb 23, 2009 | Oster Golden A5 2-Speed Universal Motor...
Jan 11, 2009 | Oster 76076-010 Hair Trimmer
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Forfex FX 684 Hair Trimmer Logo
23 people viewed this question
Top Forfex Shavers Experts
Anglia Clipper...
Are you a Forfex Shaver Expert? Answer questions, earn points and help others
