Question about Velodyne VX-10 Subwoofer
No bass... The sub woofer stopped working all of a sudden. I checked all of the wiring. The blue AUX cable is hooked up along with the power supply. It is buzzing quietly and the light says that it is on standby but there is no bass. Whats up? Thanks.
  • 124 Answers
One of a few things.
The fuse inside the amplifier section is blown.
The amplifier has died
The speaker is dead.
Best to return to the place you purchased the unit or contact Velodyne for service.
Posted on Jan 04, 2009
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
The speakers work fine apart from the sub component has lost all volume u can hear it very faintly if u turn the volume to full and the bass control to max. I've taken the sub apart to some extent...
Appears that the map powering the sub woofer is fubar. Those amps take a beating usually from being over driven. Transistors are not like tubes that will just reach a limit, distort, and stay there. You push a transistor and it will self destruct since it knows no limits ala evel knevil.
Sep 20, 2017 | Creative Labs i-Trigue 3400 Computer...
Very minimal sub-woofer power
The speaker is most likely blown out, and if it is there is no way to fix it, you will just have to replace it
Oct 09, 2009 | Logitech X-530 Computer Speakers
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
Bass in Car Gone, i don't know why!!!
Does the amplifier power up? If so, then check the voltage at the outputs...sounds like the outputs fried. Also, check the RCA cable to make sure it is getting a signal to the amplifier.
Jul 08, 2008 | Pioneer TS-W301R Car Subwoofer
Sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Dec 16, 2007 | Marantz SR-7200 Receiver
Subwoofers unresponsive
Check the physical condition of subwoofer to make sure that the surround has not rotted out or been blown away. If ok, then using an ohm meter check for the nominal speaker voice coil resistance to make sure it is within spec. If both of these areas are good then you have destroyed the output stages of the amp(s) driving them. Every 3 db of bass boost doubles the output power. So if you are blasting along at 100 watts and you jack up bass by just 3 db the amp now has to put out 200 at those lower frequencies; go up by just 6 db and you are now talking 400 watts! And what does that do to an amp when you over drive it? You guessed it!
Aug 27, 2017 | JVC MX-G50 CD Shelf System
Velodyne VX-10 Subwoofer Logo
270 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
