Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
Diswasher doesnt clean and leaves "gunk" on top shelf items
Maytag dishwasher, less than two years old. Doesnt clean very well. Cups, especialy ceramic ones on top shelf have a grimes and gunk caked into them at end of cycle. SOmetimes not all, washer makes a grinding sound when it starts up, seems unrelated to washing problem.
i use a solid pellet type of dishwashing detergent (Electrasol) and have rinsed with vinegar which is only partially helpful, first wash is cleaner but not spotless.
  • 5 more comments
  • daviddaly161 Dec 17, 2008
    it is a stainless steel dishwasher
    i dont quite understand about the rinse agent what it is or how to use it
    sorry for my denseness
    dd
  • Anonymous Jan 13, 2009
    13/01/09
    i have a maytag quiet 100 dishwasher that leaves gunk in top shelf items
    are the spray arms clooged?seems to be a bit granular resideu as well
    I'm using the same detergent-no rinse though
    mimi
    can anyone remedy this with a suggestion? thanks
  • masondtr Feb 01, 2009
    Same problem; very loud grinding sound when the cycle begins and the dishes are filthy when the cycle ends. I end up having to wash the whole load by hand to remove the dried-on residue.
    The water is very hard. I've used a dishwasher cleaner in the empty dishwasher; I've used dry detergent with a rinse agent, detergent with vinegar, detergent with rinse agent and vinegar. Nothing works.
    The washer is only a few years old and I am really unhappy with the Maytag brand--the one that is supposed to be so "dependable."
  • jdkoppa Feb 15, 2009
    ditto with quiet series 200 - stainless
    the spotting is terrible
  • Boudroux Mar 06, 2009
    I have a simaler problem but no grinding I was wandering if there is a fillter that needs emptying and how to do it
  • eruiz48 Mar 08, 2009
    I have the same thing...dishes seem to have food actually BAKED on! Cups are filthy. I took out all the screws to get to the filter, which was clogged with old detergent and filthy...I cleaned it, put the special stuff in the door that is supposed to keep glasses clear...nothing works. I saw on the news to run TANG through the washer, which I did, and the dishes got clean...one time.
  • quakesnut May 11, 2010
    Is this a stainlees steel washer? If it is, you have to use the rinse agent in the rinse agent dispenser
I had the same problem. There is a filter that the water goes through before it gets to the top of the dishwasher. If that filter is broken you will use dirty water with chunks in it instead of filtered without chunks in it to continually rinse your top rack dishes.
Rod
Posted on Mar 29, 2009
The rinse agent is a separate product. I use CascadeCrystal Clear in a 16 ounce bottle. In your machine (if it's anything like mine) there should be what looks like a screw cap next to the soap dispenser. Unscrew that and pour in the product.I was told by the appliance store where I bought my machine that you have to use this in stainless steel washers. Also I would try a liquid type soap. I use Cascade with shine shield. I think from past experience that the pellets aren't very good especially if you have hard water.
Posted on Dec 17, 2008
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
Bosch Diswasher
Remove the drain hose and check if you have any residual into it. After 11 years your appliance may need a thourought cleaning.
Check also if the pump has enough pressure.
Apr 22, 2008 | Dishwashers
I have a Kitchen Aid built in dishwasher. It has always cleaned the dishes beautifully except for the sandy gunk that it occasionally leaves on items, especially glasses and coffee cups. Recently, it...
There is a filter at the bottom of the dishwasher where the dishwasher drains. This filter is probably plugged. You may also have a kink in the drainline. The dishwasher usually drains into either a drainpipe under the sink or into the disposal. If your disposal is full this will also cause the dishwasher to not drain properly.
Jan 02, 2011 | Bosch 24 in. SHU6802UC / SHU6806UC...
Ingrained glass on top shelf
Hello. Begin by running the dishwasher after adding two cups of vinegar. Use the hottest and longest cycle u have. This will clean your machine. Then change over to cascade liquid and see if it imakes a difference. Finally, always run the hot water in the sink until it is real hot before you turn on your dishwasher.
Jul 06, 2009 | Dishwashers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
May 31, 2009 | Maytag 24 in. MDB6600A Jetclean II...
Dishwasher is leaking
Gasket probably became dislodged, replace door gaskets, at 4 years old I would replace the gaskets, they are not expensive.
Feb 17, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Top shelf items dirtier after cleaning
After some experience with our own fdw60 with the same problem, we now put all pots and pans on the top rack. Putting them on the bottm appears to stop the clean water rinse reaching the top rack. All washes since have been ok.
Sep 23, 2008 | Hotpoint 24 in. FDW60 Free-standing...
My Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. I have put through a dishwasher cleaning...
Hi shanandpop
I'm Harvey the Master Plumber.
Your question is: Your Bosch dishwasher is 6 months old and is starting to leave food on items in the top drawer. It also sometimes leaves a grainy residual in the cups and glasses. You have put through a dishwasher cleaning solution, but find it isn't doing anything to resolve the problem?
You're still under warranty. The best advice is to use it. If it is not fixed the first time out, demand a new one from where you bought it. Sometimes they drag this out till the warranty runs out, then where will we be.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Bosch Dishwashers
I have the same problem with dirty dishes on the top shelf and the utensil baskets
Dump the Kenmore on the seller's doorstep - when the place is full of customers!!
Dec 27, 2007 | Kenmore 24 in. 16264 Built-in Dishwasher
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
628 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
