Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
My daughter accidentally filled the Jet Dry dispenser of our dishwasher with Windex.
  • 117 Answers
You will need a technician to remove the rinse aid dispenser and empty the windex out. Or just buy a rinse aid that can be hung from the upper rack. The amount of liquid released from the dispenser is a small amount and I don't think it would cause a problem.
Posted on Feb 25, 2009
Where is the soap dispenser and jet dry dispenser on a Danby countertop dishwasher (with window)
I've got one of these countertop washers at home. The twist off dispenser you're talking about is for the jet dry (at least on mine) and there should be an area on the right side of the door for your soap. Hope this helps!
Jan 31, 2013 | Danby Dishwashers
Dishwasher does not dispense jet dry. Is full all the time
If the jet dry dispenser is full, it will last you about 3 or 4 months depending on how often you use the dishwasher
Nov 09, 2011 | Maytag Dishwasher
Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Whirlpool gold diswasher - sudddenly dishes/glassware/silver are all cloudy. rinse aid doesn't help. have tried running machine empty to "clean out" pipes, etc. plz help.
alot of people think the rinse aid is full but, its not. how to properly fill unit.
1. open compartment
2.fill with jet dry
3.close compartment
4.lower and raise door 3 times
5. open compartment
6.add more jet dry
7. lower and raise the door to see if it still looks full.
the reason for this is there is air in the dispenser and this process will take out the air to be completely filled the dispenser.
Mar 05, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch dishwasher leaves water at the end of its cycle cleaned filter and the impeller seams free and not blocked
check for over sudzing. dont use a cascade with jet dry in it. use regular dishwashing liquid and fill jet dry compartment. you can even jet dry level by turning the knob in dispenser.
Nov 12, 2009 | Bosch 24 in. SGS43C12 Classixx...
I can't fill the rinse aid. I do not have a
open the door and where the jet-dry indicator and dispenser is just turn the cap and once removed fill the jet-dry in that location if it a large bottle of jet-dry it will only take about 1/3 to 1/2 of the bottle
Sep 12, 2009 | Danby 17 in. DDW1802W Designer Series...
Windex in the jet dry dispenser
Dec 16, 2008 | Whirlpool 24 in. DU1100XTPS Built-in...
Detergent accidentally put into rinse dispenser
You need to use something to siphon the detergent out of the dispenser. I have plastic syringes for this type of purpose. You don't use the needle attachment.
If you cannot fit the syringe into the opening, then you may try to use clear plastic tubing to syphon out the detergent.
Once the flow of detergent stops, you should then use warm water to rinse the residue. If you have the syringe, you could use it to force water into the dispenser.
This may take a little time, but it is better than trying to disassemble stuff!
Good Luck
Jan 10, 2008 | Kenmore 24 in. 16463 Built-in Dishwasher
Dawn in the Jet Dry Dispenser
It may not hurt the machine, but it leaves soap on the clean dishes. You can't really remove the reservoir without dismantling the entire door. it's pretty straightforward, but takes a little time and effort. If you're not prepared to dismantle the door to get to the reservoir, you -could- try cleaning/rinsing it out with a turkey baster and a small diameter piece of plastic tubing. Just suck everything out, then fill it with rinse water and suck that out as well. But you'd have to fill it with rinse water over a dozen times to really get it clean. Hope that helps. ;)
Aug 09, 2007 | GE 24 in. GSD5560GSS Built-In Dishwasher
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
463 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
