Question about HP Scanjet 4200c Flatbed Scanner
Scan function will not work on my hp 4200 series
The copy and print functions work fine, but no matter what I try on two different mac laptops it will not work. What should I do? I see that other people are having similar problems, but I cannot find a solid answer on what to do.
  • Anonymous Feb 13, 2009
    My scanner won't work either. Makes me very annoyed with HP folks. The last HP printer I had broke down so I replaced it with this "freebie" that came with my Mac. Now I can't scan. Ugh!!
SOURCE: HP Solutions Center can not communicate with HP 3500c Scanner
Had exact same problem. Went to HP site and they said to check "add or remove programs" functions (in control panel) and if there are multiple copies of HP software to download their fix. I checked, had multiple copies, downloaded patch and all worked well again.
Posted on Nov 06, 2008
  • 12 Answers
SOURCE: hp 2700 series all in one printer scanning issues
Hi .
Let me first explain that the scanning softwareis seperately loaded into the computer which is called as Digital Imaging. Try the step below:
1. try scanning from scanners and cameras - 2 errors might pop up if it does not scan - an error occurred communiating with the scanning device / no HP device detected.
2. start - programs - locate for a software loaded called HP Solution Centre / HP Director.Open the software if loaed and try to scan from there. If its not loaded then insert th installation cd and click on Install more software - full.
3. In HP solution Centre / Director click setting - scan settings - scan to ..... setup - see that both the columns of front panel and available destination list should be having some icons into it (you can add and delete from any column as desired - but none should be empty)
Click the link below to ssist you with relevant troubleshooting -
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=40990&lc=en&cc=us&dlc=en&product=420428&lang=en
If none of the above work then try uninstalling and re-installing the printer software all over again
Posted on Apr 13, 2008
  • 359 Answers
SOURCE: HP c3150 has stopped scanning under mac os 10.5.4
Mac released v10.5.4 on June 30, 2008. The latest Mac driver on the HP site (http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=219&lc=en&dlc=en&cc=us&lang=en&product=1146336) was dated January 2008.
If you are using / have used the "Full Feature Software", per the HP guidance issued at http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00652016&dlc=en&product=1146336, the All-in-One software should be uninstalled prior to installing an update to the operating system in order to prevent potential future issues. [This is included for your information, as if the product is on your system, it may help to remove it.]
It would appear that perhaps HP has not yet caught up with Mac on this one. I would suggest using the "Contact HP" link from the driver page listed in the first paragraph. The online chat is often fairly quick, especially if there is a definite answer (as in "we haven't updated that driver yet"). If there is a workaround, perhaps using a driver from another printer with some particular option(s) chosen, they will have it in their database. However, I believe that is the only manner in which this problem may be definitively resolved.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Sep 18, 2008
  • 47 Answers
SOURCE: hp scanjet will not copy to print
FROM HP, searched and found after three or four weeks of unresolved solutions .. and that's fixed the problem !!
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Posted on Oct 12, 2008
SOURCE: the picture that i scan is not clear
My Canon Scanner says to clean the glass window with Alcohol, let dry, to get rid of the lines. I haven't tried it yet, but they list it as a Maintence procedure.
Posted on Nov 19, 2008
I can not scan from my HP Photosmart C7180 All in one. Mac OSX 10.6.8 I can copy, print but not scan.
Launch the OSX system preferences, click on the Print & Scan Icon located in the Hardware row, select your printer in the left hand column, click the Scan button above the right hand box, click on the Open Scanner button, a new window will open, click on the scan button in the upper right hand corner of that new window, set your document on the flat glass panel of your multi function printer/scanner, and click the scan button located in the lower right hand corner of the window, once scanning is complete, your document image should appear in a new window and save the image from there.
Dec 22, 2013 | HP Photosmart C7180 All-in-one Printer Fax...
US-4A Keyspan USB Server
if urs is a 3 in one u wil have scan and copy functions also included in this sir.
is urs a 3 in one?
Jun 21, 2008 | Keyspan USB Server US-4A (d47710) Print...
My laptop prints blank pages no matter what I print or what kind of file. The printer is an HP all in one. I've uninstalled and reinstalled the drivers. Didn't work. The prints by itself just...
This looks like a DEP problem (Data execution Prevention) which is part of Service Pack 2 (SP2) on your computer. To solve the problem, DEP needs to be set on: DEP only for critical windows programs and services (I don't know if this is the correct translation). You will find the DEP settings on your windows help function. .
Jul 01, 2011 | Samsung ML 1710 Laser Printer
Printer will not scan to computer.
You will probably have to go to this page to download the new Mac drivers for Snow Leopard to get the full functionality of your All-in-one printer back.
Print functions are generic enough where you don't need to have the most updated driver for it to work. But the scanning functionalities are more complicated.
Find the driver for your computer here:
HP drivers download for PhotoSmart C4480
May 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
I have a 1210 all in one printer that I want to install in my new Dell computer that has Windows 7. My 4200 series printer works fine , but I want to use thje 1210 at a different location than my 4200. I...
As HP saya" A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product".
Please visit the following HP web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01796879&lc=en&dlc=en&cc=uk&lang=en&product=90764
:) Dr Tony
Apr 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
How do install the scanner part of a 4200 series in a mac leopard osx? i dont know how to scan on a mac...i dont see the icon for scanning
how do install the scanner part of a 4200 series in a windows vista?the scanner doesn't work ...i dont see the icon for scanning
Aug 07, 2009 | HP DeskJet F4280 All In One Printer InkJet
HP 2410 prints & copies fine but won't scan.
Well if you are able to copy from your printer,it suggests that the hardware is perfectly fine.Its just an issue with the software.May be you are using an old software that is not compatible with the new operating system of your computer.If this is not the problem then try uninstalling and then reinstalling the software.And mind that when to uninstall the software do it completely from the registry,program files as well as add/remove programs.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP PSC 2410 All-In-One InkJet Printer
Printer prints blank sheets
I would suggest resetting the printer options to Default first. If that doesn't do it then reinstalll the complete printer software and be sure to deleted all the old software. To delete files completely download <AppCleaner> it's free and is fantastic. Your last resort is to then call Epson Tech Support.
Apr 04, 2009 | Epson Stylus CX9400 Photo Printer
Printer won't print
mac OS X 10.5.5 update disabled some printers.  you have to reconfigure the printer on your computer
Jan 30, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Cannot operate scanner
Just posted two solutions to my problems. see here.
http://www.fixya.com/support/t134648-scanner_not_working
Hope it helps
Nov 02, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP Scanjet 4200c Flatbed Scanner Logo
215 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
