Question about Forfex FX 789 Hair Trimmer
Not recharging please tell me what to do my rechargeables do not recharge . they only run for about 2 min. any suggestions?
0 characters
1 Points
How long to recharge "7"
Approximately 6 hours from "dead" level.
Once charged - should take 1-2 hours max.
Sep 19, 2011 | Shavers
Where are the rechargeable batteries located and can any rechargeable battery work as a replacement?
The battery is inside the shaver body. You must remove the rubberized grip to access the screws to disassemble it. You can not use any rechargeable battery. The battery is lithiun ion. The correct battery is available at See link below
Jan 13, 2011 | Braun Pulsonic Rechargeable Cordless Men's...
Battery no longer charges
Your Rechargeable batteries (built in) could have been dead..and needs to be replaced.
Normally they die in 2 to 3 years depending on the frequency of usage.
Generally there are 2 ea AA size NiMH rechargeable batteries soldered into the main frame .
It is not a pro business to replace it but it needs some electronic hand man involvement to replace them.Good luck..
Oct 06, 2010 | Shavers
Rechargeable batteries can become weakened over time by light use and light charging. Try running the shaver totally flat and then charge the shaver over night. If this gives you back your batteries back their charge then in future run the shaver until flat each time before charging.
Jun 11, 2010 | Remington Microflex R-845 Electric Shaver
Shaver won't recharge
If this is the case your Rechargeable batteries (built in) could have been dead..and needs to be replaced.Normally they die in 2 to 3 years depending on the frequency of usage.
But before taking it to a repair shop ,make sure you check the power cord as well,because sometimes one of the lead cracks at the point that it attaches to shaver for charging,which the power cord needs to be replaced.
If you wish you can describe the problem more details than I may suggest something else.
Apr 17, 2010 | Braun 360° Complete Electric Shaver
The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Feb 03, 2010 | Braun Shavers
Won't hold a charge and don't know how to open battery compartment.
battery needs recharging,let clipper run completely out then try to recharge
Dec 23, 2009 | Shavers
Rechargable battery won't charge
may be that the rechargeable battery is faulty call braun tell then you received this as a gift and they should be able to supply you with another one good luck
Oct 07, 2009 | Braun Shavers
My battery will not recharge
The battery has finally degraded to the point that it won't hold or pass voltage, so yes it needs to be replaced. Luckily, with a few skills, such as disassembly and soldering, you can remove and reinstall a new, rechargeable battery that should get the razor working like a champ.
Electric Shaver Service stocks most rechargeable replacement batteries for almost all electric shavers made.
Here's a link to the battery page, just find your model and you're ready to go. If you want, you can call and confirm which is the correct replacement battery for your specific model shaver too.
Hope you find this Very Helpful and best regards!
Aug 16, 2009 | Norelco Shavers
Braun shaver model 5501 won't turn on anymore.
You probably need to replace the rechargeable battery which dies after a few years (no longer can be recharged) like all rechargeables .
Oct 18, 2008 | Braun Syncro 7526 Electric Shaver
Forfex FX 789 Hair Trimmer Logo
21 people viewed this question
Top Forfex Shavers Experts
Anglia Clipper...
Are you a Forfex Shaver Expert? Answer questions, earn points and help others
