That same thing happend to me. the way u solve that is to up load the serves of the mp3 if u need more infermatoin visit my you tube acont its called Blackheart667
Hi Cedric
Yes the chord is the charging cable and the download/upload cable.
You will plug it into the usb port on your computer for charging.
You will need Windows Media Player installed in your computer ...after it is installed add your songs to Windows Media Player, then plug your Mp3 player in with Windowns Media Player running, your mp3 player will be recognized and then you can add the songs you added to Windows Media Player.
Please take time to rate me
Bud
Assuming the player is charged. (For charging always connect directly to the computer, not through a reader or hub).
When buttons on the player do not react, reset the player:
Disconnect the player from the computer.
See that the HOLD button is not engaged.
Gently push the RESET button on the rear side: use a narrow pointed
object, like a paperclip.
Did synchronization of the songs in Windows Media Player fail ?
For transferring songs, check in Windows Media Player:
1. The player is detected in Windows Media Player 10 or higher.
2. Setup the Library / Add to Library: add the location of songs you want to transfer in the library.
3. Create Playlist; give the list a name and put songs in a playlist
4. Sync Playlist: transfer the list of songs onto the player and wait for the message until you're allowed to disconnect.
Hello. Please follow these steps to put music on your Mp3 Player.
Start off by putting a battery in you Naxa mp3 player. This is necessary in order to add music to a Naxa mp3 player. Naxa mp3 Players require one AAA battery and this battery goes into the back of the device.
Plug your Naxa mp3 player into your computer. To do this, take the cap
off of the bottom of the player. You will then be able to plug the Naxa
mp3 player directly into a USB port on your computer.
Open Windows Media Player and then click the "Sync" tab found at the very top of the program.
Once you do, you will notice that the Naxa mp3 player is listed in the
top right corner of Windows Media Player.
Double-click the "Library" link on the left side of Windows Media
Player. Once you do, several different options will appear underneath
"Library."
Click the "Songs" option found below "Library." Once you do, a list of
all of the songs in your Windows Media library will appear in the
middle of the program.
Browse through all of the songs in your library and right click over
any song you want to add to your Naxa mp3 player. After you right click
on a song, you will need to select "Add to Sync List." You will then
see the song listed in the column on the far right side of Windows
Media Player. Continue doing this until you are finished putting music
on the Naxa mp3 player.
Click the "Start Sync" button located underneath the list of music you
selected in Step 7. The music will then be added to the Naxa mp3 player
Thry the solution below. If it does not work then you need to reformat. Also you might want to go to the coby website and download a updated version on the firmware and reflash your player. This will set it back to factory settings.
Open Windows Media Player.
Find and click the "Sync" tab. This is located at the very top of the program.
Plug the Coby mp3 player into one of the USB ports found on your computer. Depending on the exact Coby mp3 player that you own, you can either plug the player directly into the USB port or by using the cord that came with the Coby mp3 player. The name of the Coby mp3 player will appear in the top right corner of Windows Media Player.
Click "Library." This link will be on the left side of the program.
Double-click the "Songs" option in the middle of the screen.
Scroll through the list of music on your computer until you find the songs you want to put on the Coby mp3 player. Right-click on the title of the song and a drop box will appear. Select "Add to Sync List." You will then notice the song listed in the column located on the right side of the program.
Repeat the previous step until you're finished putting songs on the Coby mp3 player.
Click the "Start Sync" tab located beneath the list of songs you chose in Step 6. Those songs will then be added to your Coby mp3 player.
if you have a windows machine, first plug the mp3 player in to one of the empty usb ports on your computer and let windows install it, now use windows media player to songs to it using sync or copy music to device
Plug mp3 player in to usb. Does your computer recognize mp3 player? If yes, than go to "start menu" than "my/computer", than you will see drive folder with mp3 player. Leave this window up.
Now find your music folder with songs. Click song file, drag file to mp3 player drive folder and drop it in there. It will be added on your mp3 player.
Another way mabey easier, is to open media player, click sync device, Now media player can read mp3 player. In media player, find your songs in library or the folder that has them. click on "songs" or song file and drag it to the right side of media player and add it to the list of songs that will be added to mp3 player. Once all the songs are in the list on the right side, you can click the button at the bottom and they will be added to mp3 player.
IF YOUR COMPUTER DOESN'T RECOGNIZE YOUR MP3 PLAYER, YOU WILL NEED TO SEARCH AND FIND THE DRIVER FOR IT AND INSTALL IT.
Put it in MSC mode,Plug into your computer,open My Computer,(The player will show as a drive)Open up the player,open the folders and delete what you want deleted.Then when you want to add more songs,Open it the same way as above and drag and drop them.You do NOT need to use a media player to load or remove items.And Please rate this solution.
first you have to turn your sansa on and go to the setting and then you have to go to usb mode and ptu it on "mtp"
then plug it back up to your computer and this time when you plug it up the computer will start detecting it and when add song use your windows media player
Hi , Use windows media player.Plug your player into your pc using the usb cable provided.Open windows media player , click sync located on the top bar between burn and media guide.A small window should open on the right of the player titled "ypk5" drag your songs onto this list , once all your music is added click the green sync button.your tunes will start to be loaded onto your player.hope this helps
