Question about Denon DRA-397
Denon DRA 397 Won't Turn On
Hi, I went to turn on my Denon DRA 397 the other day and I noticed that nothing happened when I pressed master power.  Then I noticed that the red light that is usually on when the power was off was not on either.  It's like the receiver is not getting power, however the other electronics that were plugged into that outlet still work.  Perhaps the circuit got over ridden?  Is there any easy fix to this?
Me too did you ever get it fixed
Posted on Jan 06, 2010
I have a Denon DRA 397 receiver and when I power it up the standby light goes on but nothing else powers up?
If you are not pressing the power button on the remote that may be the problem
Apr 11, 2012 | Denon DRA-397
Dra-397 shuts down 1 second after turning on
There's a couple of possibilities; power supply shutting down because of a fault within it; the PS shutting down because of excessive current drawn and that can be caused by a failure in the final amplifiers which are probably modular in design.
Apr 24, 2011 | Denon DRA-397
Denon dra 397 shuts done if I turn on both zone a & b. Have a 100 watt volume control on each pair of speakers. Works fine with only zone a or zone b on, but not both.
Let's understand this - you have an external volume control wired in series with each front speaker set?
Can you elaborate on their electrical characteristics?
http://www.retrevo.com/support/Denon-DRA-397-Receivers-manual/id/696dj087/t/2/
Page 24.
A + B 8 - 16 ohms
Jan 22, 2011 | Denon DRA-397
I have a Denon receiver dra 545a that won't power on... how costly might it be to repair
Sounds like the power supply went out. Check inside to see if a fuse is blown. Replace it once (with the exact rating) and if it blows a second time, then you have something shorting out and can be costly to repair. DO NOT replace the fuse with a higher rating for it might cause a fire.
Oct 31, 2010 | Denon DRA-397
The scren says panel lock on. how do i get out of this mode
Denon panel lock was not supposed to be supported on this model, somehow yours is. We need to reset the microprossessor.
as denon manual states:
switch off the unit by pressing power.
keep both speaker a and b pressed and turn on the unit by pressing power.
check that the entire display is flashin at 1 sec intervals and release buttons.
the mircoprossor has been reset.
if step 3 does not work start over again.
the receiver will go back to factory defaults.
let us know if further troubleshooting is needed.
Cheers!
Feb 15, 2010 | Denon DRA-397
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
Remote lock on
This worked for me, but I'm sure tired of constantly searching for ways to fix the problems I encounter with my Denon DRA-397. When it works, it's great, but I don't have a degree in electrical engineering. Why can't they produce a user friendly trouble shooting guide?
Dec 14, 2007 | Denon DRA-397
Panel lock on dra 397
Speaker B and Mode buttons held down simultaneously while engaging master power, unlocked my DRA-397. Thanks!!!!
Dec 02, 2007 | Denon DRA-397
Remote locked
I had the same thing happen. This fixed it...
1. Press master power switch OFF
2. Hold down Speaker A & B buttons simultaneously then press master power switch
Display will flash at 1 second intervals denoting that the microprocessor has reset.
3. Release Speaker A & B buttons
Remote should now work.
Sep 01, 2007 | Denon DRA-37
Denon DRA-397 Logo
1,331 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
