Question about Hobart HL600 Legacy Stand Mixer
95 year old hobart mixer: two pole single throw switch
The knife switch looks like it has a spring which is broke. the spring would encourage the blades to move at fast speed to minimize arcing when thorwn. the mixer itself is said to be 95 years old and it could be wired for 110 volts but it also has enough wires in the switch box to possibly be three phase. the switch was wired for 220 volt and i need to find a replacement part for two pole on/off
  • 640 Answers
Im a tech for hobart and have seen old mixers but not that old.Hobart wont have parts but you could goto an electrical supply place,take the switch and ask them for something universal.
Posted on Dec 18, 2008
What is hobart h600, single phase or 3 phase?
Not sure if you are asking if an H600 is automatically a single phase or a 3 phase and the answer is NO. Depending on the motor it will be 1 phase or 3 phase application. It will have 4 wires versus 3 wires -- hope that makes sense 3 of the wires are "HOT" on a 3 phase and only 2 are "HOT" on a single phase Motor.
Jul 09, 2014 | Hobart H600 Stand Mixer
How do i check the stator on my a200 hobart mixer, or in other words ohm check the stator wiring
usually 2 wires that AC current goes through. check with volt meter set to ohms test for resistance . if you know the value .of resistance ? but if the machine has power but does not run . you know there is a thermal fuse hidden .once blown it does not reset..so you can throw it away. please don't..just replace the fuse or get a resettable one Radio shack or local electronic store . it is a size of a ADVIL pill with 2 wires inline of power coming in to switch ... >^.^<
Mar 29, 2014 | Hobart A200 Stand Mixer
Type of switch
The start switch should be a single pole momentary switch which engages a latching circuit. When you press the stop button it opens the latching circuit. The latching circuit is usually a relay, but it could be a centrifugal switch on the motor. I can't find a wiring diagram to be able to tell you for certain.
I needed to know the PH for a h600 11344142 Hobart mixer... And is it a single Or 3 face??
Hello Jbabajanov,
I understand that you want to know about the HP (Horse Power) of a H600, 60 quart mixer and weither it is a single or three phase.
All H600 Hobart mixers are equiped with a 2 horse power motor.
As to wether it is single or three phase you will need to look at the service tag of the machine. If is listed on it weather it is single or three phase.
Thank you for choosing FixYa.com
Justin
May 13, 2011 | Hobart H600 Stand Mixer
I just bought an old Hobart mixer....All the
www.hobartservice.com enter your zip in "locate an office" it will bring up your local Hobart office.
May 16, 2010 | Hobart D300 Stand Mixer
Hobart H600 Double Pole Breaker
You need to get a new electrician; a real electrician would read the power requirements on the motor name plate and install the correct voltage and amperage circuit.
A single pole breaker does not supply the same voltage as a double pole breaker. It hums because the voltage is wrong
May 31, 2009 | Hobart H600 Stand Mixer
Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Mar 06, 2009 | Hobart H600 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Hobart A200 Worm Gear Shredding Brass Gear
no there are no adjustments . you must have bent the case just a little , i dont see any good news for you , sorry . i have worked on hobart mixers for years and you should get 5-10 years out of that gear
Jan 15, 2009 | Hobart A200 Stand Mixer
My electric stand mixer stopped mixing - the motor stills runs but nothing mixes
You hopefully broke a keyway. Which is usually the case. (The key on the shaft that engages the motor worm gear is the place to look. Sometimes the center shaft gives way. Check all three gears.
The transmission uses grease. So "taking a look at it" is not a easy task.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Apr 30, 2008 | Hobart A200 Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
332 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
