Question about RCA HD61LPW163 61" Rear Projecection HDTV
RCA DLP PROBLEM AFTER POWER OUTAGE
My RCA DLP set (Model: HD61LPW162 Chassis: ATC322M) has a problem after a tripped circuit. After resetting the power, the bulb came on but not enough to light the screen, the power button blinked a few times and then just stayed on. I have no picture or sound. Now, only the power button will stay lit and will not function when pushed. The remote has no effect. It is like the software has locked up. I have this set connected to a heavy duty power center, so I shouldn’t have received a surge. I have unplugged the power cord to both the set and the center with no results. I left the power cord disconnected for a couple of hours. There is the sound of a relay when i plug the cord back in. I checked the bulb and it is ok. I even operated the lockout switch on the bulb access door just to see if that would get a response. Any suggestions? Is there an internal reset like I have on some HVAC control boards? Thanks for any help.
  • 431 Answers
Hi I am vortash I have a number of these sets with faults on the go at the moment they seem to have a life of their own or not as the case may be ?. I have just downloaded the manual for this set and it has a fault finding section you might try it was from http://www.safemanuals.com this may help I am unsure still looking for an actual schematic let me know how you get on
Regards Vortash
Posted on May 22, 2009
Mitsubishi 73"DLP wd-73638 won't turn on after power outage or getting unplugged
In most cases, this can be due to curropted software [firmware]. Contact the authoriized service center for Mitsubishi. Please do not try to update the software by yourself. It is a very skilled work to this set. Gopakumar Gopalan Google
Feb 24, 2014 | Mitsubishi Televison & Video
Steady blink green light, WILL NOT RESET!
Thats a common problem with that model which is the V26 chassis. The V26 DM repair kit available at www.tvrepairworld.com should repair that issue. The kit contains the replacement capacitors and the CD with detailed instructions its 35.99 which includes shipping
Oct 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Due to a power outage i am now not able to set the
Yes you must unplug this stove wait for 5 minutes and the plug it back up, push the off button and this should reset the oven, if that does not work the circuit breaker has been tripped, it may look to be in the on postition, but you will need to move to the off postion and back to the on postion this should correct the problem
Oct 18, 2009 | Kenmore 33169 Gas Single Oven
Blinking Gren Light on 52 Inch DLP
It most likely burned out the Lamp. DLP TV's need time to cool the Lamp after power is turned off.The fan will run for a few minutes after a normal power off condition from the front control button or the remote.When you lost power, the lamp was still hot and was unable to cool down.You can replace the Lamp yourself.Go to www.dlplamps.com
Jul 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Powercom BNT 1500AP quit working after power outage
From your description it appears one or more batteries are bad..The circuit breaker on the Power Strip..which more then likely is a 15 Amp..tripped due to over current conditions..check the batteries and reset the circuit breaker..That should take care of it
Dec 28, 2008 | Powercom (BNT-1500AP) UPS System
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
Rca dlp schematics
what chassis number is your set? Should be an ATC number on the rear of the set. Let me know that number as each series DLP is different for voltages
Feb 15, 2008 | Televison & Video
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
RCA HD61LPW163 61" Rear Projecection HDTV Logo
237 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
