Question about Maytag PYG2300A Gas Dryer
Won't start Get no response from dryer when pushing start button. The breaker is fine the door sensor button appears to be working, it clicks when pushed and released, the timer makes no sound when set on its cycle, but I don't remember if it ever did.
  • 943 Answers
Hi check the thermal fuse at the rear of the dryer It looks like this won't start - 00208689.jpg
Posted on Dec 16, 2008
Dryer won't start
the timer could have went out or maybe the door switch is stuck open
Jan 08, 2013 | Dryers
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
DRYER WON'T START
it may be in the start button or it may be a sensor on the door is not working properly. you also may have a breaker issue. on alot of dryers you have a 2 pole breaker and if you lose one side of the power at that breaker it can lose some of its capacity to operate certain functions on your appliance
Feb 17, 2012 | LG DLE5001W Dryer
The dryer will not start when you push the button. The light does come on on the inside and I did check the breaker prior to that and both appear to be fine. Is there a way to reset this dryer? kenmore...
Sorry to read about your problem, I hope this helps you out.
you may have a defective motor 80% chance or bad control relay
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
sdfsf
Dec 23, 2010 | Dryers
Dryer was working fine a load finished and when i started a new load it would not work meaning when i pushed the button nothing happened
Might be something as simple as the "settings" knob is not completely reset.... or the circuit breaker is open at the fuse panel... or the door latch sensor is not tight.
So, check each (in the order listed) and I suspect that you will correct the problem
Feb 03, 2010 | Dryers
Kenmore Dryer 70 Series. Push switch in and just a little clicking noise. No motion. Took top & front panel off, belt appears to be fine. Suggestions Please??
set timer push button in for dryer to start dryer did not start, timer is working and door light is on,what could be the problem
Oct 17, 2009 | Kenmore 60172 Electric Commercial Dryer
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Fisher Paykel ED56 auto sensor dryer - just not working!
It might be the circuit breaker of the mains/AC line. Pls try using another outlet/source of power. Alternately, most dryers have their own circuit breaker at the back of the unit. This would appear to be a push button switch, pls try see if your unit has one and press on it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 25, 2008 | Dryers
Open Questions:
Maytag PYG2300A Gas Dryer Logo
226 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
