Question about Canon imageRUNNER C3200 Color Printer
Scanner Seperates Documents
I have a user who when scanning, the document gets seperated (i.e. 3 page document scans through as 3 seperate documents). Hardware: Canon ImageRunner C4080i Software: PaperPort. What will help resolved this issue? Thanks.
  • 3 Answers
Are you using the scan to e-mail option on the copier? If yes, then maybe the fragmented document option is activated. This causes the copiers to seperate each page into an individual document.
If it's only one user, then it might be the way his e-mail adresse was put into the address book. Check that entry.
Hope this gives you some insight.
Posted on Jul 18, 2009
How do i make multiple pages scan as one document rather than each pages saving as seperate documents?
One of two things I can suggest:
1. make sure you are not scanning in JPEG or TIFF format as these are typically single page documents only. PDF is your best option for scanning.
2. Check settings, as some scanning software has an option that you can turn on or off depending on whether you want a single file with all pages or multiple files each containing a page.
Mar 09, 2015 | Canon PIXMA MP180 All-In-One InkJet...
How do i scan multiple pages and have it as one document, instead of each page being seperate documents?
there is setting for it search in file setting in scan dialog box
show add page dialog after scanning.
X544dn scanning and Windows Server 203
Scanning documents at the printer
1 Load the document into the scanner.
Note: Documents may be loaded into the scanner in multiple ways. For information on the different methods of loading documents into the scanner, see the User's Guide that came with the printer.
2 Touch Scan to Network. If prompted, enter the user name and password used to access the printer. Contact your system support person for login information.
3 Select the destination where you want to receive the scanned document. If prompted, enter the user name and password required to access the destination. Contact your system support person for login information.
4 Some additional job options may be available depending on how the application has been configured. Follow the instructions on the screen to update the options. Contact your system support person for more information on each option.
5 Touch Scan It. Depending on how the application has been configured, you may have the option to preview and make adjustments to scanned pages.
6 To scan additional documents, load the next document into the scanner and select one of the following from the confirmation screen:
• Touch Yes, to same destination to scan the document to the previous destination.
• Touch Yes, to a different destination to scan the document to a different destination.
• Touch No to finish the operation and return to the printer Home screen.
Jul 23, 2012 | Lexmark X544dn All-In-One Laser Printer
Need user manual and software for a HP ScanJet 4p scanner
HP ScanJet 4p Scanners - How to Use the Automatic Document Feeder (ADF) gtabseps.gif
gtabblt.gif Tips for Using gtabblt.gif Step 1 - Load the Paper gtabblt.gif Step 2 - Scan the Document gtabblt.gif To Scan a Single Page gtabseps.gif Tips for Using
  • Remove any paper from the copyboard glass before using the ADF.
  • Straighten any curls or wrinkles from documents before putting them on the document tray. If this is not possible, do not scan these documents using the ADF. Instead, use the copyboard glass or make a photocopy of the documents and scan the photocopies.
  • Remove staples, paper clips, and any other materials from documents.
  • Avoid documents with tears, perforations, or punch holes.
  • Do not use the ADF to scan sheets of uncommon paper or other media, such as the following: - transparencies - gummed-backed paper - magazine pages - lightweight ("onionskin") carbons
  • For paper smaller than 5 inches (127 mm) by 7 inches (178 mm) or larger than 14 inches (356 mm) by 8.5 inches (216 mm), use the scanner glass instead of the ADF. Paper smaller than the minimum size may cause a paper jam.
  • For paper lighter than 16 lb bond (60 g/m sq) or heavier than 32 lb bond (120 g/m sq), use the scanner glass instead of the ADF.
  • Before scanning, always push the front of the ADF downward to the scanner to ensure that the magnetic latches are engaged.
Step 1 - Load the Paper Besides the instructions below, quick reference decals on the input tray and access hatch show the order of steps for paper loading.
  1. Turn on the scanner.
  2. Ensure the scanner's scanner glass is free of paper.
  3. Turn the green paper load lever into an upright and open position. Refer to decal number 1 located on the ADF access hatch.
  4. Put the top end of the paper stack face up on the input tray. Refer to decal number 2 and pointer arrows on the ADF input tray.
  5. Push the paper stack up against the green document guide and slide it right against the green registration stop, which is in the middle of the paper load window.
  6. Turn the green paper load lever 45 degrees into the closed position. This will secure the paper stack. Refer to decal number 3 on the ADF access hatch. The ADF is now loaded and ready for scanning.
Step 2 - Scan the Document The ADF works with many software packages that are compatible with the HP ScanJet color scanners. To scan a document, refer to the user's manual of the software package being used. To Scan a Single Page To scan a single page while the ADF is installed on the scanner, do the following.
  1. Remove any pages from the ADF input tray.
  2. Raise the ADF.
  3. Place the page on the scanner's copyboard glass.
  4. Lower the ADF all the way and do the scan.
Sep 23, 2011 | HP Office Equipment & Supplies
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Its scannong a documents crerating a seperate jpeg file per page, can i scan into a complete document and how?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It depends on the software you're using for scanning.
In the case of the "HP Solution Center" - when you choose to "Scan Document":
On the first screen you get, just below "File Type", you can choose the option "Save to File Save Options…".
On the next screen (again, just below "File Type") you can, as desired, Tag/Untag the option "Create One File Per Scanned Page…"
Jun 18, 2010 | HP OfficeJet 4215 All-In-One InkJet...
I would like scan 30 documents using the ADF and have 30 seperate files created to be renamed later as days of the month.
If you keep the multipage switch (checkbox) ON, you will get a single file with 30 pages. If you keep it OFF, the scanner will give 30 Image/PDF files.
S. Mohan
Sep 15, 2009 | HP 5590 ScanJet Flatbed Scanner
Canon DR-7080C Missing page size selection in scan properties
tried this?
Jun 10, 2009 | Canon DR-7080C Flatbed Scanner
Problem scanning multi page document
You do not say which software you are using but if you can afford PixEdit you can save to multipage tiff, Pdfs and so on. Also combine singlepage and mulitpage documents to one mulitpage and vice verca.
May 05, 2009 | HP Scanjet 8350 Flatbed Scanner
Seperates the pictures from the text when scanning
Stop scanning as an OCR. Scan as a PDF or photo and it will scan it exactly as it was on the scanbed.
When scanning for OCR OPTICAL CHARACTER RECOGNITION it is translating the text for notepad and saving the pictures at the end or in separate files.
Mar 30, 2009 | Microtek ScanMaker i320 Flatbed Scanner
Canon imageRUNNER C3200 Color Printer Logo
83 people viewed this question
old marine
old marine
