Question about Olympus FE-170 Digital Camera
Olympus FE170 digital camera shows battery compartment empty with batteries in place I have the same problem. When I place fully recharged batteries in the Olympus FE 170, the camera won't power on at all. When I first did this, it would power on once and then when I went to take a picture it said the battery was too low. If I put new disposable batteries in camera it works. Camera is only 1 year old and barely used.
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
On rechargeable batteries, check the mAh on the side, you would need to be about 2300 or more. also the shelf life on some rechargeables may be less than desireable... try lithium digital
Posted on Dec 18, 2008
I have an Olympus FE-48/X-44 purchased in January this year, I've had problems with the batteries although fully charged, showing a red battery sign within minutes (low battery) I have tried many...
Hello everyone I phoned olympus on 08001114888 and they said to go into Settings then 'battery type' and chose either alkaline (normal) or NiMH for rechargeable - problem solved!! Not in instructions!!! Previously could only take about 6 photos without 'battery empty' message or the lens going in and out as above. This SHOULD sort out your problems so you can keep the camara :)
Sep 07, 2011 | Cameras
Keep saying battery empty evn whn i just charged them
Some rechargeable batteries (NiCd and older NiMh) have a (bad) memory.
If they have, the charger cannot fully charge the batteries to their original
potential capacity.
Best thing to do is to buy new rechargeable batteries and a processor
controlled charger to prevent premature malfunction of your batteries.
There are new type precharged batteries which have a very low discharge
over time. Like the Sanyo Eneloop and such!
Jul 15, 2011 | Olympus FE-310 Digital Camera
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
May 16, 2010 | Olympus SP-550 UZ Digital Camera
Camera or battery problem?
Sounds like a battery problem. When a rechargeable battery is allowed to completely discharge from non-use, it usually will not come back.
Dec 15, 2009 | Olympus EVOLT E-510 Body Only Digital...
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Olympus 550 UZ battery
you may want to use lithium batteries... i find the rechargeables in most cameras to not last as long... also you may need to clean the contacts in the battery compartment with alcohol and let air dry
Jan 04, 2009 | Olympus SP-550 UZ Digital Camera
Shows empty battery even with new batteries
If they're AA, don't use "HEAVY DUTY". They don't have enough power. Use alkaline or rechargeable, and recharge at least 15 hours even if your charger show they're fully charged after a couple hours. Please leave feedback if this helps.
Jul 26, 2008 | Olympus FE-210 Digital Camera
Battery empty
Try using fully charged rechargeable NiMH.
Oct 19, 2007 | Olympus Camedia C-350 Digital Camera
Olympus FE-170 Digital Camera Logo
190 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
