Question about Sony KV-36FS100 36" TV
Just a clicking sound when trying to power up
I have a KV36FS100 Sony. I just get a double click when trying to power up. No picture, no sound. There are about 10 flashes of the led on the timer then two flashes repeatedly. Is there a defective relay in the power supply I should look at or could there be other problems.
    Genius:
  • 1,074 Answers
Your set you should take to a tech to repair you cannot do it by your self.goodluck.you have an defective power supply or a defective microchip.
Posted on Mar 23, 2007
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
I have a SONY VGN-CS215J, Windows Vista, and my touch sensor A/V controls aren't working, how can I solve this problem?
Try this..
  1. Click the Start button, and then click on Computer .
  2. In the Computer window, under Hard Disk Drives , double-click on (C:) .
  3. Double-click the Windows folder.
  4. Double-click the DRIVERS folder.
  5. Double-click the .EXE folder.
  6. Double-click the Pointing Driver (Synaptics) folder.
  7. Double-click on the setup or setup.exe icon.
  8. Follow the Synaptics Pointing Driver Installation wizard instructions to install the driver.
You can also try downloading and installing the Touchpad Driver.
You can download the Touchpad Driver here.
hope this helps....
Jul 30, 2010 | Sony VAIO VGN-CS220J/W Notebook
Sony digital camera-Takes great pictures-when I upload to computer pictures come out tiny squares(colored) where the picture should be. Sounds like camera setting error. Don't know how or where to fix...
Try using a card reader to download your pics to a folder you create on your desktop. Then, double-click the folder to open it and from the menu on the left, choose to view as a slide show.
Dec 02, 2009 | Cameras
I have no picture or audio on my TV. The green
It sure sounds like the mainpower supply problem, the power supply may be trying to turn itself off because it detects short circuits.
Nov 01, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a problem with my webcam sound. I recorded my assignment speech and when i try to listen to the speech, there was no sound coming out from the webcam. i tried everything and nothing worked. Can you...
Hi chinonsobeau,
First off, you to list the model number of your HP web Cam, as well as your OS, and the software you using to record your sound. I will assume that you have Quickplay which HP ususally send out with their web cams.
To access QuickPlay, just press the "blue QuickPlay button" next to the power button. If it doesn't load QuickPlay, just do "Start" - "All Programs" - then you will see QuickPlay listed there. If you still can't find it just do a search, you will find the short-cut. If you still don't find it, then HERE is a place you can download it and use it. It also has instruction on how to use it.
Or sometimes HP sends out Cheese, another camera software. You can download that HERE.
These are the instructions for QuickPlay:
Once launched QuickPlay, click on the 2nd icon from left (between DVD and TV icon), then double-click on "HP Pavilion WebCam" from the left side panel, then you will see the blue LED light lit and you should see yourself on the screen. (Double-click "yourself" to enlarge image)
To take a picture or record video, just press the corresponding buttons on the top. (the red circle icon is for recording video (press "Stop" icon to stop recording), the camera icon is for, well, camera)
Videos and pictures are saved at:
Pictures -- C:\Users\Public\Pictures\My Snapshots
Videos -- C:\Users\Public\Videos\HP Webcam
I'm less familiar with Cheese, so I'll give you their website HERE to go to their support and they can guide you through their program.
Anyway, I hope this helps,
Don't forget to leave a raing,
Thanks
Mark
Videos -- C:\Users\Public\Videos\HP Webcam user_offline.gif
Oct 11, 2009 | HP Computers & Internet
Power clicks on and red power light flashes but no picture
The problem might come from the fuse inside was blow out. if you have a multimeter then open the rear cover. The fuse lays near the power cord. Take it out and use Ohm meter to check it connectivity. If it is no connectivity meaning the fuse was blow out. Replace a new one with the same value (Ampere and Voltage). If it does have connectivity, the problem needs technician to find out as it relates to many parts on the circuit board.
Aug 11, 2009 | Sony KV-27S46 27" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
Sony KV36FS100 - Has sound but no picture and stand by light blinks when TV is off
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 24, 2017 | Sony KV-36FS100 36" TV
Transfering pictures to computer
fi you have three other devices connected as drives then you see them all or else everything went bad - bad disk!?
try unplugging you usb cable from the computer. check to see haw many drives are there now - you could even go sofar as to safe removal of all drives. then reboot computer. after finnished booting, replug in usb cable and power up camera. it should recognize it now.
Feb 27, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony KV-36FS100 36" TV Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
