Hotpoint ctd40g tumble dryer
Power turned on lite switch press to start operation house electrics trip .Is it worth spending money on a 3year old machine?
  • vanscratchy Dec 27, 2008
    all lights work enter program press start and electric trips out
  • Washing Mach... Master
  • 3,463 Answers
If you are located in the u/k, then you should be covered by Hotpoint 5 year guarantee, all parts are free you pay for labour and call out.
It might be worth you checking the heater at the rear of the m/c located behind a removable panel. disconnect one of the wires going to the thermostat and try it , if it does not trip, then it could be heater, also you might have damp where heater is ,use hair dryer to dry it all, and make sure all your filters are clean, and that the water tank is empty.
Plz rate this solution.
Thanks.
Posted on Dec 18, 2008
I have an Hotpoint CTD40G, if I load it with a full load it strugles to rotate and stops.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Hotpoint TDC32 Electric Dryer
Everytime i turn on my condenser tumble dryer the fuse box trips out
In your house electrical panel make sure the screws are tight on the breakers; especially the screws on the white wires (neutrals).
Mar 19, 2011 | Hotpoint Dryers
My ctd40g tumble dryer has recently started smoking and the drum is no longer spinning, can you help?
Your dryer motor might been short circuited and the motor needs to be rewind or replaced.
Nov 11, 2010 | Hotpoint TDC32 Electric Dryer
My hotpoint condenser tumble dryer keeps triping the mains in my house when i try to switch it on
you could have a defective start switch on the dryer motor, bad motor bearing making motor drag and draw excessive current or a heater element shorted to the dryer case
Oct 18, 2009 | Hotpoint NLL113EYWO Electric Dryer
I don't have any heat from my hotpoint aquarius ctd40G Tumble Dryer. I have cleared all the fluff from the condenser unit and unplugged the mains and tryed it all again but we still do not have any heat...
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint condensing tumble dryer
i would bet its your breaker b4 the dryer / larry
Nov 29, 2008 | Dryers
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Hotpoint tumble dryer ctd40g
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 11, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius CTD40G dryer not heating up
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Dryers
How to fix Hotpoint CTD00 Tumble Dryer?
http://www.fixya.com/support/t232066-hotpoint_ctd00_trips_power
The link above should solve your problem. I have the same problem and my parents who bought the same tumble dryer also had the same problem. Its water backing up to the fan then its hitting the heating element which is tripping the electric off.
At the back of the Tumble dryer near the bottom you'll see a panel that has about 8 screws that you can taqke off as well as a small panel that cover the pivet for the drum. If you unscrew this you will see the fan and heating element and no doubt a small puddle of water and damp dust that has clung onto the panel. You should dry this with kitchen roll and clean the old dust off then carefully turn the tumble dryer on (at your own risk lol) or you can take the advice of the person who posted the link above and use a hair dryer. This will stop the element getting wet and tripping off.
Also there is a water reservoir to the right of the panel i mentioned. If you prise the clips open and remove the top section you will see the water in the reservoir. If you look inside it on the bottom left hand side there is a little **** that the water drains in from. If you use something like pipe cleaners or a knife and wiggle it about you may have some fluff or hair trapped there that is making the water back up to the fan and causing the tumble dryer to trip off.
Hopefully this willsolve your problem for the time being but the filter in the bottom of the dryer needs to be cleaned thoroughly every week or so to stop this happening again.
Personally i think this is a major design flaw and the tumble dryer should be recalled but Hotpoints aftercare service is awful to say the least so lesson learnt, don't buy a hotpoint tumble dryer!
Feb 01, 2008 | Dryers
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
