Question about Kitchen Ranges
Kenmore range control panel not working
We have a Kenmore range, model 790.9468. We heard a loud popping sound while the oven was on at 350. Everything shut off. The breakers were flipped, & I reset them. Since then, the control panel is lit up with ''Bake'', ''self clean'' and ''cook time''. None of the buttons are operational, but the oven light works. The stovetop burners work, but the oven will not.
Suggestions?
  • pkmmvkc Dec 16, 2008
    Thanks for responding so quickly. Can you tell me what could have caused this & if we can do this ourselves? I hope so, because my husband has been laid off, & we are definitely watching expenses!
    Thanks again.
    pk
  • aquajacq Dec 30, 2008
    No buttons working on the control panel of my 5-year old Kenmore electric range (Model C970-6570). Stovetop working and oven light working. Problem as preceeded by two large sparks (or small fireballs!) at a 2 week interval while baking at 350.
    Opened two parts of the control panel and found a 'crater' where there was once solder, and a lot of black soot. Bought and installed a new relay with tabs built into the relay, and this should have worked... Darn, it didn't. Anyone know where can I get an inexpensive or rebuild control panel?
  • 8,197 Answers
Sounds like the control board blew on you replace it.
Posted on Dec 16, 2008
  • Jyackle5
    Jyackle5 Dec 16, 2008
    What would cause it is a short on the unit. Yes you can replace it yourself. There are 3 screws on the back top of oven remove them and then you will see the control board. I would recommend you call some one to look for the short though.
2 Suggested Answers
SOURCE: Kenmore electric range 790. Both the broil and
I have the same problem... I checked both elements and they are fine. I was wondering if it was the ERC. Have you fixed yours yet? Please let me know.
Posted on Dec 06, 2009
Heard a loud "Pop" sound, now oven won't work and lost digital display. Stove and lights (even in oven) all work fine. Breaker did NOT trip btw. Odd.
When my range digital display lights failed everything as you describe happened except the "pop". The display just faded and died. I replaced the display unit (a simple swap out involving pulling the wires one at a time and reconnecting to the new display as I pulled them so as not to connect wrongly). Once done I haven't had a problem since and the display was noticeably brighter. It appears that the display unit only affects the ovens operation for heat control and everything else is on a different circuit which is why your oven light and rings are still operational.
Mar 02, 2016 | Kitchen Ranges
Kenmore range model c970-535121. Heard loud pop stove breaker and main breaker both tripped. Now everything functions except bake and broil do not work. Also noticed when push buttons on control panel
Sounds to me like you have a short in the bake and broil section. Check the wiring and see if a wire has come out of an area and grounded its self. Shut the power off when checking this out and you should find out where the short is so you don't shock yourself . Also check for wires that appear like they are burnt as this indicates where a short could be. Be very careful as this could be dangerous. If you don't know what you are doing call a repair man .
Dec 02, 2014 | Kenmore Kitchen Ranges
My Kenmore stove, model #79095680301, was baking some food when it made a loud popping sound. Since then, the control panel doesn't work (and we can't turn on the oven without the control panel). The stove...
Joe,
Sounds like you need to contact a qualified Kenmore technician. It could have burned out an element, wires to the element, etc., but you'll need to be fairly skilled to check these components.
Try contacting Kenmore directly here:
Kenmore Customer Care Customer Service Information
Feb 08, 2018 | Kenmore Electric Smooth Top Stove
I heard a "pop" sound
main control just went bad order a new one.
Mar 08, 2011 | Kenmore 96213 Electric Kitchen Range
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
I hace a 2003 Kenmore Electric Ran ge #790-95682. Five minutes after turning the oven on to preheat, I heard a loud poppong noise and spark near the left side of the burner controls on the display panel....
your bake element blew look at it to see if it is broken. if it is replace. the main breaker blew in breaker box .most likely .or a wire is burnt take off back panel and look .unplug first .good luck
Aug 23, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
While oven was on, heard loud pop. oven no longer
Sounds like your element wire shorted out on back of unit.Try removing back panel and cheak wire on bake element .MAKE SURE YOU UNPLUG OR TURN OFF BREAKER.Hope this helped you out:)
Mar 11, 2010 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
1,859 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
