Question about Mach Speed Trio DA-8033 MP3 Player
Wont turn on
Starts for 2 to 5 seconds and turns off. I cant start it. It would be very kind if you could give me a solution asap to the problem. The product is Mach Speed Trio DA-8033 MP3 Player ,thank you.
  • 3 Answers
Here's how I fixed mine:
Turn on your MP3 player, it should be blinking. Plug it into your computer and wait for it to link up. Then use your computer to format it, THIS WILL ERASE EVERYTHING, so copy off your music before hand.
Then go to this web site and download and install the software:
http://www.machspeed.com/tech/firmupdate.html
Now when you start the software, if it doesn't find your MP3 player (it didn't find mine) it will say your firmware version is 0. Go to the DETAILS button. It will list four files (it will show five but two are the same file) for he update. Locate these files on your computer and copy them to you MP3 player.
Pull out your MP3 player, and it should now work. Hope this helps.
Talerith
Posted on Mar 10, 2008
I have exactly the same problem. Pls go to http://www.machspeed.com/tech/firmupdate.html to update firmware to solve this problem. I guess update firmware is somehow like update bios of a laptop. Goodluck.
Posted on Jun 15, 2007
I have the same proble for the 1gb mach trio mp3 player. I used to format it to solve this problem. Now I am thinking of throw it away. Too annoying.
I'm not sure what the problem is, but i have the exact same MP3 player and it does the same thing. It won't even say the welcome screen, it will just starting blinking the backlight with a blank screen until you pull the battery out. it is annoying, and one of the worst MP3 players i've had.
Posted on Apr 24, 2007
80 series landcruiser wont start
Hi Waza, Why don't you guys don't like to give us the info we need to be able to help you? Is the engine cranking or is it failing to turn? What fuel are you starting up on? Have you checked for spark and are you getting it? Please let us have info? Regards John
Feb 21, 2014 | Cars & Trucks
Stalls on driving wont start runs for 2 to 3 seconds then dies
You don't say what year or engine. but I would try checking the idle stop solenoid and the choke adjustments. You give more info I could help more
Mike
Sep 12, 2017 | Dodge Caravan Cars & Trucks
2001 yz 125 wont start
is fuel freely flowing to the carb i.e. is fuel tap blocked
Mar 12, 2013 | Motorcycles
How to turn off theft the van cant start
cant turn off problem you can try another key.put key in the ignition turn on position for 3 seconds the security light should turn off.then turn off ignition switch wait 5 to 10 seconds try start vechicle if still fails to start.problem in the theft security system.dealership has to code scan problem could be in the ignition switch which is antenna ring.problem could be transponder key or problem could be in the immobilizer control module and ECM.
Feb 11, 2013 | 2000 Ford Windstar
Car wont start at all. Cranks but wont turn over
1. Fuel pump.
2. Alternator.
But you need to go for a scan. But it is a fuel system error thgat has made other things malfunction.
Aug 22, 2009 | 2001 Toyota Highlander
How to replace an ignition switch in a 1991 honda accord ex
my car wont start. it was working fine . i check the starter, the alternator and the battery and there ok. im guessing its the wiring but i cant seem to find out wat wire it is.. please help.. asap..
Jun 12, 2009 | 1991 Honda Accord
Motor wont start
sounds like your keys lost programming. will only start for about 2 seconds then shut off. security locked you out. will have to have your keys reprogrammed
May 18, 2009 | 2006 Dodge Magnum
Cant start
add fuel and then turn igniton on for 3 seconds turn it off for 5 seconds for like tree or five times and try this will bleed any air from fuel lines
Jun 01, 2008 | 2000 Cadillac DeVille
Mach Speed Trio DA-8033 MP3 Player Logo
146 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
