Question about Panasonic SC-HT730 System
Connecting tv to surround sound
Can't figure out which cables go where.
  • 8 Answers
Look at the back side of the TV .
There will be [more than one] composite video in & out
How composite video port looks like typical 3 RCA jacks - std color of ports are Red, White & Yellow. The yellow one is the one - which carries video signal. You can connect - a RCA cable from output of SC-HT730 [yellow] to back of TV.
Most probably there will be at least one Component video behond your TV set [ if the set is HD Ready one] - in other words, If your TV supports component in.
Component Video ports are namsed as Y Pb Pr - if you have so, connect output from SC-HT370 to back of TV.
Recommendation: choose component video - if that is supported in both. That gives much better picture quality.
Posted on Dec 17, 2008
2 Suggested Answers
SOURCE: Sony surround sound hookup
Did you get a reply? I need the same answer
Posted on Jan 08, 2008
How do I connect a samsung c555 home cinema system to a LG 42LD450 42 inch tv so that i can get sound out the built in freeview? also cant seem to get sound out my PS3? I have connected the video output...
Use an optical cable from ps3 to surround sound and hdmi from ps3 to tv.... But I can't get my samsung surround sound to come out of the tv with built in freeview either. Just wondering if you figured it out. Cheers
Nov 14, 2010 | Samsung Audio Players & Recorders
I have succesfully connected my dynex 32" lcd hdtv 720p 60hz to my rogers digital box and my xbox but i only have room to connect my audio cables for my surround sound speakers to my tv cables there is no...
What cables are you using for the XBOX and the digital box? What surround sound system are you using (what receiver)? Which model of Dynex 32" TV do you have? Looking at the DX-L32-10A, I can connect both devices to the TV and then the audio out to the surround sound system.
If HDMI, then that will carry the audio to the TV and then you would need an audio cable from the audio out on the TV to the surround sound speakers. Similarly, if you use component video and the audio cable combination, there are 2 component video jacks and 3 audio-in jacks on the rear of the TV. Then connect another cable from the audio out of the TV to the surround sound system. (This TV has one audio out and a headphone jack.)
If you previously had the audio going from the Rogers digital box directly to the surround sound system, you need to reroute things unless there are two or more sets of audio in jacks on the surround sound system. Some surround sound system can take several HDMI in cables and then route it to the TV on a HDMI out port.
Without more information, I can't be sure of the best option for your cables.
I hope this gets you started and please provide more information for additional suggestions.
CIndy Wells
Sep 17, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Dec 22, 2009 | Sony Playstation 3 (PS3) Console
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
How to hook up wii to surround sound
You need to connect your amplifier to your TV, (Video Out of Amp to video In of TV), then select the input where you connected your WII in amp.
Or you could just connect the yellow plug to the TV directly, and the white and red plug to your amplifier.
A note thou, Red and White will not give "True" surround sound as it has only 2 channels, you need to connect a digital input to the amp to get true surround.
Let me know what happens
Alex
www.CAS411.com
Mar 15, 2009 | 2006 Chevrolet Uplander
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Surround sound problems
you need an optical cable which it's sort of mentioned in the manual, but because of the multitude of possible ways to connect the TV to the sound surround, I did not figure out either.
I got my optical cable at BestBuy for about $45.00
Jan 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
Dec 24, 2007 | Samsung HT-X50 System
Using surround sound
Good Day;
Connect HDMI cable to TV then audio cable back to "SS".
Good Luck, big IRISH.
Dec 15, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Panasonic SC-HT730 System Logo
171 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
