Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover F7425-900 won't run at all.
When you turn the power on the pump in the lower handle unit buzzes and nothing else happens. The motor does not come on and the brushes don't turn either. Ideas?
  • 107 Answers
Yes you have a bad motor and possibly bad turbine. I have never done this but have read success stories with opening the turbine and spray it with WD40 and spin it to get it going as it gets rusted and jams. I prefer to replace it rather than a quick fix. The motor must be replaced as well and will cost you probably 100 between the both of them, give or take 20 bucks. You will also need the seal for the motor. You can get all these parts through sears. The link is below. I also gave you the reference numbers for sears so you can just click which ones you want rather than search the schematic.
Part numbers:
Turbine 91001097 #23 not #23a
Motor 27212077 #17
Seal 38781074 #21
Sears Parts Store
Posted on Dec 17, 2008
When you turn it on the lights on the battery come on and the brush roller will turn but the suction motor will not turn on.
Hoover Air Cordless Series 3.0 Bagless Upright Vacuum ...
www.amazon.com/Hoover-Cordless-Bagless-Upright...
Amazon.com, Inc.Hoover Air Cordless Series 3.0 Bagless Upright Vacuum, BH50140 ... The batteries come pre-charged, plenty to get up and running. ... The brush will stop as soon as the handle is in the upright position for like using the attachments. ..... and in need of charge, in carpet mode, the motor runs, but the brush roller won't spin.
Hoover Air Cordless Series 3.0 review - Best vacuum cleaner
www.vacuumsguide.com/hoover-air-cordless-series-3-0-review/
Rating: 4 - ‎Review by Jason Roberts
Aug 4, 2014 - Hoover Air Cordless Series 3.0 is a new upright vacuum cleaner reviewed by ... power, 2 batteries - each lasting 25 minutes, good filtration system,light ... Just as in the case of the Linx, it filters dust particles, but doesn't come with HEPA filtration. ... Multi-Floor Cleaning - you can turn the brush roll on or off.
Dec 18, 2015 | Hoover Air Cordless Series 3.0 Bagless...
Linx Hoover platinum won't turn on
more than likely you'll have to order a new handle. Those machines are built in pieces so you just cant replace switch, motor, etc....
Feb 13, 2013 | Hoover Platinum LiNX Cordless Stick Vacuum
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
I was cleaning my carpet using my hoover steamvac ls. I had already changed the water 3 times. The last time, the water ran out and I kept running it for a couple of minutes trying to **** up some of the...
(1) take the tank off and reassemble to assure you sealed to the lower handle.
(2) the water feed has nothing to do with the motor or electrical, purely mechanical.
Hoover web site is free, no cost.
Sep 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I HAVE A HOOVER SAVVY AND THE BRUSHS WON'T TURN.
there is a small circuit board right above the motor on the base ,look and see if there are any burn marks or discoloration.if the headlight isn't working either then thats the problem .the circuit board.you can get it through all-type vacuum and janitorial 314-275-8006 supply.$18.49.there is a belt that runs up the center from the roller to the geart on the motor
Apr 01, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover s3765 windtunnel power head does not run
I have the exact same problem as you have. Have you found a solution since you posted on Mar. 18, 2009? Thank you.
Mar 18, 2009 | Hoover S3765-040 WindTunnel Bagless...
Eureka Atlantis Stopped Working
I would contact eureka for warranty repair. sounds like it there is something wrong with the mechanis of the unit. could be that water is making its way into the motor pump housing and causing damage to the pump
Aug 09, 2008 | Eureka Atlantis 2595A Upright Wet/Dry...
Hoover steam vac
I had the same problem just before the impeller broke. Lower the handle and check the hose connection at the bottom is not broken. Turn the unit on with the handle down, then check the suction on the accessory hose, leae it disconnected. Take off the bottom container, and check the suction on the round intake tube (lower one towards the front), with the handle up and with the handle down. If the suction increases dramatically when the handle is lowered, the impeller is probably in it's self-destruct stage. (same as mine). Soon the impeller will break off, and BINGO no suction at all.
Jun 25, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
78 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
