I have a an image ......but when copying it to another drive it give me a message "data error cyclic redundancy" i really need this file , can you help me plz .. thnkx
  • 145 Answers
I am very sorry to say the drive( I think its a floppy) is corrupted. Try using Scandisk (Tools tab on Disk properties, then error checking). But that too has limitations and I won't guarantee it will solve, still trying does no harm.
Posted on Dec 19, 2008
Data error. Cyclic redundancy check
This application protects the privacy of user information and does not forward your personal data to some kind of external services for PST file analysis.
Oct 28, 2017 | The Computers & Internet
The NASTY "CRC" Error ......Tackle IT
What does CRC(Cyclic Redundancy Check “error”) mean?
There are plenty of technical resources on the Web that discuss cyclic redundancy checks (CRCs). Most times you won't need to worry about this technobabble. That is, until one it day it suddenly appears and you think - what the hell does that mean? In simple terms, a CRC is bit of mathematics used to ensure that your data is OK when being transfered. It's a checking procedure that quickly identifies when data has been damaged. If you get this message, it means that the file being read by your PC or software is corrupted. However, it does not mean all the data is lost forever. When data is transfered, it is usually in small blocks and each block is given a CRC value. If something goes wrong with the data between the time it leaves the source and arrives at its destination, the CRC sent at the source will no longer match the one that is calculated when the data arrives - this is when the cyclic redundancy check error will appear.
The most common time you will see the cyclic redundancy check error message is when trying to read data from a damaged CD or DVD. Just before it appears, your CD/DVD drive will probably grind and whirl away - your PC may also become a little slugglish.
Less frequent causes are the result of system crashes, and buggy software (hello Microsoft), incomplete downloads (often identified by the misleading message 'This is not a valid Windows file', 'This is not a valid win32 application' or 'Corrupt Zip file'). If this problem happens frequently with downloads, try using a download manager.
For CDs and DVDs, the problem is a little different. Normally, when CD/DVD drives get a CRC message from a disc, they try to read the disc again - hence the grinding sound. After several failed attempts, they give up and display the redundancy check error. The problem can be hardware (loose cables, failing drive), software or damaged media. In most cases checking and cleaning the disc is the easiest way to overcome the problem. If different clean discs produce the same error, it is likely to be a hardware issue (check the discs in another drive). Another common cause of these errors is poorly burnt CDs and DVDs - especially those that had numerous or severe buffer underuns. USB burners suffer from this problem when the burn speed is too high (generally above 4X-8X)
If the discs are damaged, you'll probably need a recovery tool to get back your data. CDCheck 3 will work for CDs and DVDs. First it will check the media, and then you have the option to recover the files. It's free for personal use and has saved many people heartache when it comes to recovering lost digital images and videos from damaged CDs.
on Dec 22, 2009 | Computers & Internet
Data error cyclic redundancy check
This is some serious problem when u get it on the data important? try formatting the hdd and use it....
Dec 29, 2013 | Transcend Computers & Internet
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to for more information
Feb 20, 2013 | Computers & Internet
Cyclic redundancy error when copying backed up files into Itunes
Files with cyclic redundancy errors means these files are corrupted and cannot be copied. Since you cannot copy these files from your faulty hard disk again then these songs are lost and you need to download them again.
Nov 27, 2012 | Apple iTunes
Cannot Copy File:Data error (cyclic redundancy check).
Try to download" Long Path Tool " is also useful in situations where you see these error messages: Cannot read from source file or disk, there has been a sharing violation, cannot delete file or folder, the file name you specified is not valid or too long, the source or destination file may be in use and many other file managing errors.
Dec 27, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
A "CRC" (Cyclic Redundancy Check) is caused by an disk-drive error.
When you write a "block' of data to your disk-drive, a CRC value is calculated, and is also written to the disk. When you try to read that "block" of data, the CRC value is also read from the disk,
and a new CRC is calculated from the data. If the "new" CRC does not match the "old" CRC, then you have a "check" condition -- either the data was not written correctly, or the data could not be read correctly.
Now, did the "check" message refer to the "source" of the copying operation (namely your 'C:' drive) , or the "target"(namely the external drive) ???
Try to copy the PST file to another file on your 'C:' drive.
If you do not see the "check", then it is the external disk-drive that has a problem.
If you do see the "check", then open Outlook, create a new folder,
and copy a group of messages into the new folder. If Outlook reports that one of the messages could not be copied, then the disk-space occupied by that message is faulty, and must be excluded.
Sep 07, 2010 | Computers & Internet
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Mar 01, 2009 | Computers & Internet
Cyclic Ewdundancy
cyclic redundancy means the actual data comosing the file has been corrupted. dvd shrink sometimes corrupts data when the compression is turned too high. CRC errors are problems in the base Hexidecimal coding used above binary coding that the proccessor uses.
Basically, you need to get new data cause that one is gone.
Jan 14, 2009 | Computers & Internet
Moving files from Windows xp
The file on the hard drive is corrupt, run scandisk and fix the file error, but the video is likely a loss
Jul 06, 2008 | Dell Dimension 8100 PC Desktop
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
