Question about Refrigerators
I have a water issue with an american style fridge freezer .The water is fin e going into fridge ,but the water and ice is tainted when discharged from the freeze . Something in the fridge is tainting the water If anyone has come accross this problem , you might let me know
  • nealsweeney Dec 16, 2008
    Hi ,
    The firdge was fine for the first 9 months ,water and ice perfect . then the water became tainted , I changed the filter .The water is absoulutely fine entering the fridge ,ie drinkable , but when it is dispensed , the water and ice is tainted , almost tasting metallic , possible a mercury type taste.Someting is occuring , / breaking doen in the fridge itself ? Amy ideas
  • 8,197 Answers
If it is a new fridge or just hooked up the watter for the first time you need to cycle the ice a couple of times. What the coler is is charcal from the filter. Discard the firs two baches of ice then it will be fine.
Posted on Dec 16, 2008
  • Jyackle5
    Jyackle5 Dec 16, 2008
    Sound like the coating on the ice machine is coming apart. Replace the ice unit.
Freezer not making ice
Is it an icemaker? Either the water valve is bad or the freezer isn't cold enough or the ice maker is bad. Is it just a ice cube tray? Then it's not cold enough.
Aug 25, 2016 | Samsung RSH1DTMH American Style Silver 524...
Refrigerator leaks
If it a frost free fridge it should self defrost every 6 to 8 hours all by its self. If you see ice or frost buildup in side the freezer usually back wall harder to notice if the cooling fins are just under the freezer floor but above the fridge ceiling or better picture it as the fridges taint. Sounds like the fridge is having defrost problems and if it every once in awhile does go into defrost or you do it, all that water flows down a hose and out the back around the compressor. Heat from the compressor or other gadgets evaporate the water. If it only defrost a few times a year it is going to overflow the catch basin. Easy to check some times catch basin or drain hose move check back bottom or remove front cover look if bottom catch basin. Main fault is defrost timer stuck in run, location all over in or out, defrost element around cooling fins,defrost thermostat on cooling fins,wiring to / from / joining the last two.
Mar 17, 2017 | KitchenAid KBRP20ERSS Stainless Steel
Hi, i have a whirlpool american style fridge that beeps etc.
its the compresor packed up,,,if this compresor is not pumping freezer gas around the pipe work the freezer wont work sorry but a new compresor is not a cheep thing to have fitted as it will need a re-gas as well
Jun 29, 2010 | Freezers
Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 04, 2010 | Refrigerators
Hi freezer on american style fridge freezer is
there is a defrost mode that melts any frost or ice on the evaporator coils and drains it into a pan under the fridge. if that drain is blocked, the water will pool inside. also check the door seals. if warm moist air leaks in, it'll condense on the cold interior and pool as well.
Nov 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Jul 23, 2008 | Refrigerators
Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
Mar 09, 2008 | Refrigerators
Refrigerators Logo
55 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
