Question about Panasonic CT-32SX12 32" TV
Circuit board where can i find a new or used circuit board? would replacing this part fix my problem with the fuse blowing? thanks for your help. Joey
    Genius:
  • 1,074 Answers
Try wwww.ptscorp.com they might be able to help you.replace the power supply of ypour tv it have a short with a diode or the regulator.if you cannot do it yourself take it to a tech.
Posted on Mar 23, 2007
How I fix the window unit airconditioner blow the fuse in circuit board
you have a short unplug each section one at a time from the board fan then compressor and try it each time to see which one does not blow the fuse you may lose a few fuses but you will find out where your problem is
Sep 02, 2014 | Heating & Cooling
Why is my VAX 121 blowing my fusebox ?
"Blowing" FusesWhen a fuse blows, replace it with an identical [same Amperage rating] new fuse.
IF the replacement fuse also blows, then that is an indication that there is either a short circuit condition in that circuit, OR you have an overload condition due to too many electricity using devices connected to that circuit, or one that draws too much electrical current [current is measured in Amperes (Amps), or milliamps (thousandths of an Amp)].
The fix" for repeatedly blowing fuses is to troubleshoot the circuit involved, find and identify the fault, properly repair it, and then install another good fuse
Jun 25, 2014 | VAX Appliances Vacuums
GE Model# jvm1850sm1ss microwave has lost all power. The light bulb was not secured in its mount as it should be. When I took off the bottom panel the light moved, touched other metal and caused a small...
Sorry, when you do not unplug the machine before removing the buulb the wires at the bottom of the bulb twist together and blow up the main circuit board. The fuse will not respond fast enough to save the board, the traces that blow off of the board were never meant to carry that kind of amperage and they blow off before the fuse can respond. ALWAYS unplug a microwave to replace the bulb. I have seen a lot of units damaged that way. Need either a new circuit bosrd, or someone to repair the blown traces on that one and test it. Sometimes it damages other parts on the board and you cant turn the light on or off, sometimes always on. New board time, But $$$$
Oct 18, 2017 | Microwave Ovens
Hi i changed colour cartridge tried trial run printer died; changed fuse in plug; still no power any suggestions please
in the printer there is a power supply board.there is a same type of 3amp fuse on the power supply board.if there is any kind of overheating in the power then the fuse in the plug and fuse on the power supply board blows out.in some cases only fuse on power supply board blows out.this fuse is placed on the board for safety reasons.because in the older model printers when this short circuit problem was happening at that time whole board used to blow out.so in the new model of printer a fuse is placed on the board ,so if any overheating or any power outage or any short circuit occurs.the fuse blows out instead of whole power supply board. You just need to replace the fuse on the power supply board by disassembling the printer.the power supply board is the green color square shaped board.its the board to which your power wire of printer is connected. the fuse is available at any local electric hardware shop.its not any special kind of fuse. This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | Lexmark X5150 All-In-One InkJet Printer
The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Nov 15, 2009 | Refrigerators
Washer fuse problem
There is a dead short on the control board. Cease using the washer and get it serviced.Constant blowing of fuses can damage other items connected to the same circuit.
Thanks for using FIXYA
Oct 12, 2009 | Washing Machines
It seems that the fuse for that board has blown how or where can I replace that circuit board
I don't know if WD are like Maxtor but M won't supply you with a replacement pcb - they want you to buy a new drive.
If you can find an IDENTICAL WD drive buy it. Take care and remove the circuit board from the new drive. (It's very straightforward). Now remove the circuit board from the duff drive and replace it with the board from the new drive.
Plug it in and test. Does it work? Does it mount?. Now copy all the data from the drive onto something else as a priority. Once you have completed the transfer, remove the drive, remove the circuit board and refit it to the new drive. Mount the new drive, format it and then copy all your files back again.
Use the new drive and keep the old for safe-keeping.
The only thing that can go wrong (other than being ham-fisted) is that there is a problem with the old drive that has caused the fuse to blow and it could well cause the fuse in the new Circuit board to blow. But that's a chance you've got to take if you want your data back.
Sep 22, 2009 | Western Digital Caviar SE WD2500JD 250 GB...
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
System won't power up
Based on your description, we can limit the fault to the power supply board and in particular to possibly 3~4 components:
  • bridge diode;
  • filter capacitor (mains);
  • regulator;
  • filter capacitor (secondary).
blown fuse indicate a short in any of these.
As Jaime867 has suggested, in the absence of a readily available replacement board, component level might be the best alternative at the moment. Having posted the most likely culprits further narrows down your troubleshooting. Could you pls post back the part number of the smaller IC either 4 or 8 pins?
Alternately, pls check for the presence of a VDR, it would look like a coin (often green in color or something else) with 2 pins. They have been known to short out also and cause fuse to blow. One possible indicator is chipped or flaked of one side or a hairline crack on top. If it is chip, there would be a silvery color on the inside.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 26, 2008 | RCA RTD258 System
Fuse keeps blowing
NEVER EVER replace a fuse and think that va fuse will blow all by itself. The fuses are there to protect the set from catching on fire incase theres a short inside the set. Now in some cases an intermittant short can work after you replace the fuse but if its burnt black or brownish, theres a short inside the set in one of the circuits. always use a 100 watt light bulb across a blown fuse if your not sure if there is a short. if there is, the light will absorb the short and glow bright. if there is no short the bulb will glow bright , then go down very dim. you could have a main power supply problem, such as shorted bridge rectifyers,shorted main b+ capacitor, Hot could be shorted, or the Vertical or audio output IC could be shorted
Sep 06, 2006 | Panasonic CT-32SX12 32" TV
Panasonic CT-32SX12 32" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
