Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Heater wont start
I plug in my heater and the fan acts like its going to spin then it dosent and the glow plug goes off
  • Anonymous Dec 25, 2008
    turn on heater thermostat shows room temp then goes to 81 deg fan turns 1 rotation then ignitor lite comes on dosent start brand new ignitor
    Problem Solver:
  • 5 Answers
HEATER NEEDS TO BE TORN DOWN AND CLEANED.ITS A DIRTY JOB BUT IT SHOULD TAKE CARE OF IT.PULL THE BLOWER IT MAY HAVE A LITTLE RUST ON THE SHAFT AND SPRAY IT DOWN WITH WD40 IT WILL NOT HURT IT.
Posted on Dec 17, 2008
How do I get the fan to operate on my electric fireplace model FL28-R?
Is the same thermostat activating the fan? You may need to change it.
Sep 25, 2015 | Heating & Cooling
Heater blows smoke out front, wont ignite...please help!
Two things cause it ,No fire at Spark plug or low air pressure
Jan 22, 2011 | Reddy Kerosene Heater with Thermostat:...
Trajet diesel dosent have glow plugs does it have a fuel rail heater
I googled Hyundai Trajet glow pugs and got a yes on glow plugs. Got nothing on fuel rail heater.
I am just passing this along.
No offense meant.
Wayne
Dec 30, 2010 | Hyundai Santa Fe Cars & Trucks
Heater wont start.Fan goes, Starts to heat, then blows a couple clouds of smoke and dies. Ive cleaned filter, new fuel. Cant figure out what adjustment I should be doing. Glow Plug? What else?
take the shield off and see if it burns with more combustion air. If it does then the heater isnt getting enough air. look for a shutter or set screw near the burner that should be the primary air adjustment. sounds like you have been working on the fuel side already. You may check the orfice to see if it is partially blocked, use a safety pin and gently **** it out. also check the burner tube
Dec 07, 2009 | Reddy Heater 60,000 BTU Kerosene...
Glow plug light not coming on, on dash. Engine turning over but not starting. Have never had any trouble starting before. The fan belt has been screeching for about 30 seconds for the last few weeks when...
Check fuses to see if there are busted ones. Then check heater plugs if good. Heater relay included in check. Engine wont fire if the air inside the chamber is cold. Then check fan belts for wear, replace if necessary.
Nov 29, 2009 | Volkswagen Golf Cars & Trucks
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Engine block heater not working/truck wont start if cold
Hi bud876 did you get a faulty block heater? if the cord and block heater are new it should work when energized double check for power, as far as glow plugs do they cycle? is the glow plug relay working properly?you would be a lot better going with a circulating heater rather than a block heater,hope this helps good luck
Nov 09, 2008 | 2003 Ford F350 Super Duty DRW SuperCab
My renualt laguna 2003 2.2dci has a cold start problem, if i spray easy start into the air filter, it starts, what could be causing the problem? regards gary
i would suggest that the heater plugs in the engine are either faulty or not working, the can be checked if you know what you are doing, they basically act as a heater inside the engine when it is cold, if they are not working, a diesel engine relies on heat i ignite the fuel airmixture unlike a petrol engine that has a spark plug that ignits the fuel. if there is no heat the fuel air mixture will not ignite. Check that power is going to the heater plugs,it will be 12 volts, if there is remove the heater plugs(easier said than done) then check the heater plugs,(the engine can not be used when the heater plugs are removed). I would sugguest getting some one who knows how to check them if you are not sure, as you have to basically put 12v to them and they glow red hot at the tip.if they dont glow when wired up they are faulty, and change them all, about £40 a set if you shop around.
Nov 01, 2008 | Renault 181 Cars & Trucks
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
65 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
