Question about Sony Playstation 3 (PS3) Console
Ps3 powered down suddenly. It won't power up. green,yellow, red
While watching a dvd my PS3 powered down suddenly. I tried to power it back up 9hrs later. It goes green for 2 seconds then to yellow then it flashes red. It will not power on!
If i where you i would send it to sony they are the only ones that can help you..
Posted on Dec 16, 2008
Playstation 3 (PS3) Console: has power go to turn it on goes to green then afte...
you got the yellow light of death, you would need to reflux solder on the processors and reheat the solder, here is a link for the repair, http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related I suggest you take it to a pro if you feel you can not do it, you can mess up your ps3 if you don't do it right and taking it apart is a delicate job.
May 17, 2010 | Sony Playstation 3 (PS3) Console
Mid game my console beeped and shutoff. Now it wont eject disk or turn on at all. Light goes Green, Yellow then flashes Red
your PS3 overheated, what you need to do is remove the power cable and hold the power button for 5 seconds to make sure that there is no power left, then plug it back in and press the eject button hold it down, it will power up and eject disk, if that fails, you need to RMA your ps3 to sony or you can try and return it to vendor with the game case or dvd case of the disk that is stuck they should replace both
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
My Ps3 is only staying on for 4 seconds (green for 2 seconds and yellow for 2 seconds) and then flashes red. when i tap the power button it stays red and repeats.
call sony the problem can be several things
call sony even if your console is out of warenty
i had the same problem a couple of months back and warenty was expired by a few months i called them and they gae me a refurbished ps3 free
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 turns green then yellow then red
The problem is known as a YLOD on the PS3 or Yellow Light of Death. Your PS3 is most probably a 60gb model as they are mostly known for this issue. The PS3 is fitted with a very good cooling system. Unfortunately some of the 60gb models still overheats (either the GPU or CPU). This causes the YLOD and is very similar to the XBox' s Red Ring of Death.
The best is to return the PS3 if still under guarantee. You can attempt to repair it yourself at own risk. There are no statistics on how long the fix lasts. Most of the YLOD consoles I repaired myself are still holding out and it seems the fix is more permanent than the Xbox 360 fix. Here is a link to the guide that must be followed and it works (http://www.youtube.com/watch?v=4_Ic1_TY-GU) The other parts in the series you will find on the same page. There are 7 parts
After the fix a couple of things can be done to prevent future overheating:
Do not keep the PS3 in a confined space.
Keep it away from dust.
To enhance airflow, remove the cover over the HDD when switching it on.
Switch it off when not playing.
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Ps3 shutdown
My ps3 shuts down as soon as i turn it on.
The light turns green then yellow, then red, and then it starts flashing red.
Does anyone know how to fix this frustrating problem?
Apr 12, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont turn back on
if you cant get your disk out of your ps3 turn off in back of console hold down the power button with the eject button at the same time turn on the console in back while holding both buttons keep holding until disk ejects might take few times
Oct 20, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
