Question about Car Audio & Video
Subwoofer acting wierd
I have a 10 inch 750watt subwoofer and a 600 watt amp in my car and i played some basstester songs on it and it stopped working today. so i turned the car off and restarted it and the woofer works but only when the volume is under 15, i used to play it on 20 and it worked fine. if i turn it up past 14 the woofer stops working and i have to turn the car off and restart it. what do you think the problem is? did i blow it?
    Problem Solver:
  • 14 Answers
If you turn the power off and restart, the most logical answer i know of is your amplifier is going bad.
I am not sure of the model and brand of your amplifier, but there should be a protection light on the amplifier somewhere that will most likely be on, caused by overloading the amplifier.
You will most likely have to replace the amplifier, or check with the manufacturer to find out if they can repair it or help to further diagnose the problem.
Posted on Dec 17, 2008
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
What watt amp would i need to power 2 Kenwood KFC-WS253 10 inch subwoofer
get a nice 600 to 1000 watts Rockford and turn it down or upgrade speakers and turn it up it is usually better to have more than you need but control it
Aug 25, 2014 | Car Audio & Video
Amp wont play
Quick test...with your Lanzar volume all the way down, connect MP3 player or other type audio source directly to the subwoofer input connection. Play audio and slowly increase volume control. If subwoofer is working using this method, reconnect and check for audio output to Lanzer connection problem, or subwoofer "settings" issues with the receiver.
Nov 11, 2013 | Lanzar VCTBS8 Vector 8-Inch Super-Slim...
What amp for a Pioneer TS-W304C 10 inch
Wow, i just answered a similar question so, pretty much the same answer.......
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Nominal power handling range is 300 watts. And a peak of 600watts. That does not mean start cranking 600 watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms. Leaves you a little headroom on the amp, but use caution.
Hope these specs help you in choosing an amp.
Jan 05, 2013 | Pioneer TS-W304C Car Subwoofer
How many watts will the 10 inch mtx thunder 4000 have
It should tell you on the back of the sub ,The continus watts it will handle, If not phone the place you got it from, Or some place that sells them,
Nov 28, 2012 | MTX Thunder 4500 T4510-04 Car Subwoofer
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
What kind of amp
It depends on the box you are installing them in. If you're going for sealed box they you can put 600-800 watts on them as long as you're careful with the gains and bass boost off. In a ported enclosure I wouldn't put more than 600 rms on them and still be careful with the gains. set your filter on your amp to about 80 hertz and match it on your source unit.
May 31, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
Backfeed problems
a noise filter, and upgrading your RCA's, i had the same problem with my subs. Heard a wierd sound when i turn my stereo off or change songs. Got some monster cable and the problem stopped
May 09, 2010 | Car Audio & Video
Wiggle the positive wire to get power and have to unplug subs to turn car off
Ok it sounds to me that your remote wire is not hooked up right casue if you trun your car off then your amp should power down an when you trun your car on it should power up
May 07, 2009 | Car Audio & Video
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
