Question about Dell Dimension 3100 PC Desktop
Windows XP won't boot
Dimension 3100 was fine...came back to it to find a blue screen. Restarted it and now all I get on the monitor is
Intel(r) 915G/915GV/910GL Accelerated SVGA BIOS
Build Number....etc etc
DECOMPILATION OR DISASSEMBLY PROHIBITED
Copyright etc etc
I've tried restarting pressing F12, F8 and F2 but nothing
Any idea what might be wrong. Much appreciated
  • 1 more comment
  • mbhume Dec 16, 2008
    I'm not getting a blue screen at all now. Just a black one with the message above
    No beep codes either
  • vernando008 May 11, 2010
    When you switch on the pc,do you see any writing on screen before you get the blue screen.And do you get any beep codes?
It turns out it was the memory. This is the second major problem I've had with memory in 28 months.
Not very impressive, Dell.
Posted on Jan 12, 2009
  • 51 Answers
Sorry for my bad english
the problem may be your hardisk data cable.change your hardisk data cable.and also try this, remove ram memory and clean it and restore.
Posted on Dec 17, 2008
'No rgb signal' to second (old) monitor
try restarting the pc in safe mode
uninstall the graphic driver restart the pc and again restart the pc
this is problem of screen resolution
Apr 10, 2014 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Dell Pc won't boot gets black screen with floating dialog box
Floating dialog box is the monitor's self test. Your monitor tests good. Your computer is the problem.
Mar 04, 2013 | Dell Dimension 3100 PC Desktop
Reinstalled Windows XP on an old computer (DELL Dimension 2400) and the monitor won't display above basic resolution. Downloaded and reinstalled the monitor driver and still no good. Opened up START
According to the Dell Support web site the Dell Dimension 2400 has a built in Intel 3D extreme graphics adapter, assuming you are using this and not a PCI graphics card.
Go to the Intel Download Centre and run their Intel Driver Update Utility which will automatically scan your system for updated drivers for any installed or integrated Intel devices.
If the Intel Utility identifies an updated driver for your graphics adapter then download and install that which should enable you to configure a higher resolution for your display.
Dec 24, 2011 | Computers & Internet
Blue screen on dell 3100 mountable boot volume
Blue screen is very common error, it mostly occurs due to corrupt registry files, you need to re register you windows. You can also use RegInOut- a utility software to fix windows errors.
Oct 29, 2011 | Dell Dimension 3100 PC Desktop
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
Ialmrnt5 video driver error
When you first boot up the computer press F5 continously until a boot menu shows up. Then choose "start windows in low-res mode". This option will start windows in the lowest resoloution and hopefully it will boot up and you can change the resoloution. If this does not work you can retry the "safe-mode" selection. If that does not work you may have a problem with the on-board video or video card.
Sep 07, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension Startup
try going into your BIOS and changing the boot sequence, it may be set to boot from floppy instead of harddrive. or you could just reinstall windows, but that sucks cuz then you lose all your data and programs. and not to be rude, but you shouldnt have bought a dell, they are full of problems.
May 11, 2009 | Dell Dimension 3100 PC Desktop
Monitor is blank on Dell 3100
try starting in safe mode and then change setting
Mar 13, 2009 | Dell Dimension 3100 PC Desktop
Blue screen
Blue screens on a system with an activated copy of Windows are usually the result of hardware changes. I would take out or unplug everything except the boot drive. If it boots OK now, put things back in one at a time and reboot. I know it is time consuming, but if you do 2 or more at a time you don't know which one is causing the problem. I would take pictures of the insides the way they are now so there won;t be any confusion. Pictures are easy to delete, but hard to create if you don't have one of the connection you are unsure of two or three days from now.
Oct 29, 2017 | ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775...
MONITOR GOES BLANK
Did you recently change or install a program that would affect the resolution and card output? Try booting into safe mode by holding the "shift" key during boot. From there right-click on the desktop and hit 'properties'-> 'display properties' -> 'settings' , check your resolution and drop it to 800x600 and then reboot. If everything goes back in normally make sure you have the right windows drivers for your video card. You can also check the driver version and settings while you're in safe mode. Sometimes the windows update drivers can act screwy and I would recommend getting them directly from your card manufacturer.
Aug 19, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 3100 PC Desktop Logo
495 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
