Question about GE DGE505N Multi-disc DVD Player
Front panel says loc how do I get rid of this
Frigidaire affinity dryer loc
LOC is a generic lock code meaning the door was either locked manually or accidentally. Also LOC will lock the control panel and can be manually locked as well. Try to reset the unit for about 10-15 minutes and retry.
Aug 31, 2012 | Frigidaire Affinity ATF7000E Front Load...
Loc on dryer
"LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. This will fix the issue.
Thank you !!
Jul 06, 2010 | Frigidaire ATF6000ES Front Load Washer
I have error code loc the machine won't
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2009 | Kenmore Elite 45986 Front Load Washer
"loc code"
Found the operating manual on the internet. We thought it was the child lock button but we couldn't release it. We found out that you have to hold both the "select" and the"option" button for 10 seconds to release the loc.
Hopes this helps someone else.
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
417.44092500 front load washer I get a LOC err,
Jun 30, 2009 | Kenmore 46462 Front Load Washer
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Error code LOC
Jun 27, 2009 | Kenmore 44932 Front Load Washer
I just get LOC message on the control panel
look closely at he control panel you mistakenly set the control lock on( its a child saftery issue, youll need to hold down a particular button for 3-5 secs to uundo
Jan 25, 2009 | Frigidaire ATF6000ES Front Load Washer
Loc error
Greetings necie64,
The control panel may be in *LOCKED* mode.
Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel.
Make sure the detergent tray is fully closed too.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
GE DGE505N Multi-disc DVD Player Logo
27 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
