Question about Brother MFC-8220 Fax
Brother copy machine 9160
I exchanged new cartridge, but not original toner.
Then few months later a line show up in the paper.
After that, one side it copys Ok but half side of A4 paper became unclear to read. how can I solve this problem. Anyone know?
  • Anonymous Apr 01, 2014
    in my machine when taking double sided copy front side ok but backside light copy problem.
    Champion:
  • 320 Answers
The best bet would be to buy brother toner, you most likely messed the drum up
Posted on Jan 17, 2009
    Genius:
  • 2,120 Answers
There should be a blue slider on top of the cartridge, but it probably is a bad drum cleaning blade inside of the cartridge.
Posted on Dec 16, 2008
What causes streaky copies
A few questions:
- Did this problem just start?
- Was there a paper jam and when the paper was dislodged the next few sheets were streaked? Running a few more pages usually clears this.
- Is this a new toner cartridge? Did you just change the cartridge? Are you low on toner? Try removing the cartridge and gently rocking it back and forth, side to side. This will distribute the toner more evenly.
- Is this a heavier weight paper then previously used? Try going back to the old weight and see if the problem continues.
Aug 19, 2014 | Brother MFC-8860DN All-In-One Laser...
Vertical line on paper from top to bottom
In my experience if you refill the toner cartridge with the toners available in the market,though they are labelled"for Brother 2140" you get vertical dark patches on the paper. Once in a while you get good quality print too. Replacement with correct toner cartridge seems to the solution.
Oct 22, 2012 | Brother HL 2140 Laser Printer
Black lines on copies and on drum
There are a few things you can do to troubleshoot this problem.
  1. Be sure you are using new, clean paper
  2. Clean the copier's paper rollers, the marks may result from a dirty roller mechanism.
  3. Clean the copier bed's glass plate, smudges manifest themselves in the final copies.
  4. Clear any excess toner that has spilled in the toner cartridge chamber. Remove the cartridge, set it aside, then clean the compartment.
  5. Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy
If all else fails, try turning down the darkness of the copies in the settings, this can occasionally lead to lines and marks.
Feb 28, 2011 | Brother MFC-8460N All-In-One Printer
When the paper comes out there are black, ink like lines on the sheet. This happened after we bought a brand new cartridge...we took it in to be cleaned, but it starts doing it again after several copies...
I saw a defective toner cartridge in a Brother just last month that left solid drips of toner on the page, so thick they peeled off in lines. If that's what you're describing, take a sample back to the store along with your toner cartridge, and they should exchange it. Might want to call ahead and see if they require bringing in the printer too.
If you're seeing thin, straight lines, and they were also showing before you replaced the toner, then you either have a drum or a fuser roller with a scratch around it. You pull the drum unit out every time you replace the toner. It's the assembly you install the toner in before putting the whole thing back into the machine.
The fuser is much harder to get to. It's the hot section in the back that makes the print permanent by pressing it between hot rollers. There's a simple, but scary test to see which part puts extra marks on the page, and that's to deliberately jam the printer. Start a test print and wait until you think the page is past the toner/drum assy. and headed for the fuser. Open up the printer, stopping it, and pull out the drum. If the paper is past the drum and headed for the fuser, look to see whether it has those lines on it. If it does, the drum is the problem. If the print is still clean, the fuser is the problem, and you're looking at a repair.
Feb 09, 2011 | Brother HL-2030 Laser Printer
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Sent faxes not printing clear
Per Brother's User manual,
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_4100_4750e_5750e_EN_98.PDF
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Greg
May 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Printer overlap
sounds like a defective cartridge, if it's a generic toner the seals may not have been replaced, buy a new one and return the other as defective.
Jun 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Illegal toner
The HL2700CN is a Tally machine rebadged by a number of manufacturers.  Each has it's own unique 'plug' on the back left side of the cartridge as you look at it in the machine.  Check that the plug is the right shape and if necessary fit the one from your empty 'brother' cartridge.
I have only ever had the 'illegal toner' message when I put in a Lexmark cartridge by mistake - swapping plugs solved it.
'Brother' machines seem to run at a different temperature than other Tally clones - so there may be a deeper problem with the toner that you used.  In my case it simply failed to fuse to the paper and I had to get another cartridge.  Check for deposits on the OPC belt and fuser rollers.
May 03, 2008 | Brother HL 2700CN Laser Printer
Brother MFC-8220 Fax Logo
74 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
