Question about Canon Speedlite 430EX TTL Flash
430ex speedlite not working
Hi I have a Canon 430ex only about 7 months old, while using it, it made a loud bang (max flash sort of noise ) after which it would not work, the flash gun still makes a charging noise which continues, but will not reset / flash any more. And the batteries get very hot very quickly. Any idea whats wrong and what can I buy to fix it, It's not been dropped or got wet at any stage HELP please
SOURCE: Canon Speedlite 580EX
Buy the 550EX, it's cheaper
Master /or Slave = 550
Slave = other
Alexander
Posted on Dec 22, 2007
SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Posted on Jan 16, 2008
SOURCE: canon speedlite 430EX
Make sure it is not set to manual 'M' on the display. To get it to shoot in ETTL (Through the lens) press the mode button and it should read ETTL in the top left corner. This then means that the light is metered thorugh the lens and you are not relying on the manual settings.
Hope that helps. I had the same problem when i first got my.
By the way a brilliant all round bit of kit. I have traveled the world to some fairly extreme temps and got it wet (Rain, humidity, sea spray to deserts and serious dust) All good.
Good luck
Posted on Jul 13, 2008
SOURCE: can't find the serial number on my 430EX
This is where I found mine:
It's a 6 digit number located on the top half of the flash (the bit that tilts backwards and forwards). On one side it says Speedlite 430EX II, on the other side there are a few symbols and underneath is the serial number engraved on the plastic.
I also found it printed on the warranty card that came inside the box.
Posted on May 06, 2009
  • 10 Answers
SOURCE: I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Posted on Oct 07, 2009
My canon speedlite 430ex does not charge up, batteries are new and rear screen works/lights up any ideas?
Sounds like an internal wiring circuit problem. It's strange that the screen lights up but the flash doesn't charge. You should probably get it checked by Canon.
Feb 11, 2013 | Canon Speedlite 430EX TTL Flash
Just got a Canon 7D. Attached my 430EX to the hot shoe and it won't fire. Tried new batteries and checked the contacts, and it still won't work. Put th 430EX back onto my Rebel XTI, where it has always...
Make sure you using flash grade batteries and not rechargables. try energiser ultra or litiums or duracelll plus but nothing else. if the charge light is not coming up then most likely batteries. I would take it to your local camera shot and test your 7d with one of thier 430 just to make sure the hotshoe didnt short out the flashgun
Feb 21, 2011 | Canon Speedlite 430EX TTL Flash
Canon 50D doesn't recognize new Speedlite 430EX II. Flash power is on and pilot releases flash.
Check the contacts on both the camer and the lens. I usually clean mine with methylated spirits or isopropyl alcohol. I have to do this every 3 months or so as dirt or even oils from your hands can stop the contacts from working properly.
Oct 30, 2010 | Canon Speedlite 430EX TTL Flash
Only get one flash when using slave
Yeah you should go into the menu on your camera and see if there is anything you need to change!!
Apr 02, 2010 | Canon Speedlite 430EX TTL Flash
My 430 is making a buzzing noise then it flickers
the buzzing noise is normal for that model .. first it makes noise as it charges and maintains the capacitor then when it auto focuses ..
here is a discussion of your speedlite model and the buzzing it produces
http://www.cameralabs.com/forum/viewtopic.php?t=19864&sid=ed65281bc80849c5fa34264a56c5f9f4
Jan 19, 2010 | Canon Speedlite 430EX TTL Flash
Trigger a Speedlite 430EX II with a studio flash
  1. Make sure the trigger you are using is compatible with digital flashes.
  2. isolate the smaller contact so they do not "short out" on the trigger.
  3. make sure the trigger is working and will fire other flashes
Nov 03, 2009 | Canon Speedlite 430EX TTL Flash
Canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
Feb 22, 2009 | Canon Speedlite 430EX TTL Flash
Flash will not power on
YOU NEED TO REPLACE THE CONTACTS ORT USE SOME AMONIA AND WATER TO REMOVE THE CORROSION.
Nov 03, 2008 | Canon Speedlite 430EX TTL Flash
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Speedlite 430EX TTL Flash Logo
90 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
