Question about Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black
Instructions for frigidaire oven
I have to replace an EOC on my Frigidaire Electric Range model # FEF365BWD ( serial # Vf33342642)---and would like some step by step instruction on installing the new EOC---any help would be appreciated. Thanks in advance. I just replaced my EOC with a new unit and the same F1 code came up when I tried to turn on the elements - any thoughts other than try another EOC??
  • 8,197 Answers
An f1 one code means that
Electronic control has detected a fault condition. Turn the Temperature Control Knob to
OFF, and disconnect the power to the range. Wait 30 seconds and reconnect the power.
If fault recurs, disconnect the power and contact an authorized servicer.
You can get all the codes here in the manual.
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FEF365BWD&User=&Search=Search
Posted on Dec 16, 2008
I AM GETTING F1 ERROR CODE ON FRIDIGEAIRE MODEL #CFEF372CS2 SERIAL # NF41924422, ONLY OVEN NOT WORKING
I am 99% positive you need a new EOC based on the fact that you said you heard the all too common pop noise. EOCs usually cost around $200-$300 and sometimes more. The EOC in this is the same as your clock, if you took off the top back you will see burn marks on the back of the clock.
Jul 04, 2014 | Frigidaire PLEF398AC Electric Kitchen...
How much is the eoc for a frigidaire range
http://www.acronymfinder.com/EOC.html please pick one That acronym makes no sense to me yet
Nov 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
My stainless frigidaire professional series electric stove oven door is locked...i did not self clean it, but it is locked somehow...if i hold either the lock button, or the clear/off button for 15 seconds...
F1 is an EOC (electronic oven control) failure. The control is expensive. But before you go and buy this board, you need to find a diagram to see of this model oven lock is controlled by the EOC or by a micro switch. If you have a lock button on the board the you have to replace the EOC.
Mar 24, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Feb 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
F1 fault code Frigidaire electric range
all solutions on the F1 show to replace the EOC control.
May 20, 2009 | Frigidaire FEF352 Electric Kitchen Range
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Thanks for the question. remove the back panel. first cut the power to the stove .remove the clips that hold the board, install new one. install the wiring on the new one. thanks the appliance doc.
Sep 27, 2008 | Frigidaire FEF366 Electric Kitchen Range
FRIGIDAIRE STOVE
F1 is a EOC (electronic Oven Control) failure... you will need to repace EOC
Aug 29, 2008 | Frigidaire FEF355 Electric Kitchen Range
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Stove beeping
You have a fault in the range electrical system
FRIGIDAIRE
Range/Stove/Oven Fault Codes Version 3 Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jun 04, 2008 | Frigidaire FEF376 Electric Kitchen Range
Frigidaire 30" Self-Cleaning Slide-In Electric Range - Black Logo
568 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
