Question about Lexmark X4270 All-In-One InkJet Printer
Letter size envelope does not fit into the paper holding tray
I can't print letter sized envelopes on my Lexmark 4200 printer because they are too wide to be inserted into the tray. There seems to be no way to adjust the sizing to accommodate the width of a regular envelope
    Novelist:
  • 59 Answers
Hi cmwww920,
Usually letter envelopes are insert long-way into your printer. I recommend using the Microsoft Word envelope wizard to print Sender and/or Recipient addresses on envelopes. Here's how it works:
1) Launch Microsoft Word.
2) Click Tools > Letters and Mailings > Envelopes and Labels...
3) Type in what you want to see on the envelope.
4) The default feed direction is shown in the lower right corner of the dialog box. To change it, click Options and select the Printing Options tab. Adjust the settings as you please.
5) Click OK to exit the Options Dialog Box
6) Click Print (in the upper right corner of the "Envelopes and Labels" dialog box.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
If envelope printing Canon PC-D340 All-In-One Laser Printer incorrect paper size problems.showing
You need to make sure the paper size and that of the printer matches in the dialogue box.
i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.
secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.
Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
Jul 17, 2011 | Canon PC-D340 All-In-One Laser Printer
Xerox phaser 7400DN jabs at fuser
The printer trays accommodate most sizes and types of paper, transparencies, or other
specialty media. Follow these guidelines when loading paper and media in the trays:
- Envelopes, labels, and glossy paper can be printed from Tray 1 (MPT) only.
- Transparencies and custom size paper can be printed from Tray 1 (MPT) and Tray 2.
- Fan paper, transparencies, and labels prior to loading them in the tray.
- Use only paper envelopes. All envelopes should be printed single-sided only. Some
wrinkling and embossing may occur when printing envelopes.
- Do not overload the paper trays.
- Adjust the paper guides to fit the paper size.
- If excessive jams occur, use paper or other media from a new package.
Mar 06, 2011 | Xerox Phaser 7400DN Laser Printer
How do i print envelopes on the HP 1350?
  • Remove all paper from the paper tray.
  • Slide an envelope into the tray, with the envelope flap up and to the left (print side down), until it stops.
  • Adjust the paper-width guide against the envelope.
  • Be careful not to bend the envelope.
  1. In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
  2. In the Envelopes and Labels dialog box, click the Envelopes tab.
  3. Click Options .
  4. From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
  5. Click OK , and then click Close to close the Envelopes and Labels dialog box.
  6. Click File , and then click Print to print the envelope.
Dec 01, 2010 | HP PSC 1350 All-In-One Thermal Printer
I have a large list of envelopes that I have to print, I have tried to put the envelopes in the tray but it won't print unless I put them in the manual feeder. How do I fix this problem?
If your printer is the Lexmark E260dn, the tray doesn't support envelopes. The tray is for letter /legal /A4 or A5 paper sizes. For smaller type of media, it has to be fed through the manual feeder. I'm really sorry but I hope I can assist you more on this.
May 13, 2010 | Lexmark E260dn Laser Printer
Not printing envelopes and printer locks up
Use a small flash light and check for any debris blocking the roller from the tray...
Sep 24, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Lexmark X4270 All-In-One InkJet Printer Logo
207 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
