Question about Toshiba Satellite A105 Notebook
Toshiba satellite p105-s6217 will not power up or charge.
When power supply charger is plugged into wall outlet and laptop the power indicator light will turn off but will turn back on once the power supply is unplugged from the laptop.
  • larrymalvado Dec 16, 2008
    need assistance a.s.a.p!
  • Anonymous Mar 25, 2014
    power supply is ok. no indication of power to the laptop
  • 3 Answers
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Posted on Dec 17, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
If your laptop has a bad battery, will the computer still be able to turn on when plugged into a power outlet?
If your battery is totally drained or dead, your laptop will not turn on even when plugged in to power outlet. The power from the charger don't have enough power to pass through the battery that is trying to charge. Remove the battery and you will be able to turn on your laptop when plugged in directly to wall outlet.
Sep 21, 2010 | Toshiba Satellite M35X-S163 Notebook
The battery is not charging despite the computer being plugged in to mains power. I have downloaded the latest BIOS.
It could be the fault of the battery charger. It may be dead despite the light on it saying that it is charging. Check with a multimeter if it has an output.
Jan 09, 2010 | Toshiba Satellite P105-S9722 Notebook
I install Memory flas for laptop toshiba P105-s6217 and restar laptop and no work anymore only working fan and nothing more
take it out and see if its ok. if it is than its bad memory or wrong memory or it wasnt in all the way
Dec 01, 2009 | Toshiba Satellite P105-S6104 Notebook
When i plug my pc I get no power indication. does
Check the cable on the power adapter, and make sure that it is plugged tightly into the wall, AC adapater, and then into the Notebook.. I know it seems obvious, but sometimes the connections are not tight.
Check the power outlet or plug it into another receptacle.
If you are still experiencing the same problem, does it still run on battery power?
Does the power indicator on the task bar.. or other area depending on what operating system you are running.
please let me know if this answer was helpful to you by rating my reply.
Thank you and have a good day !
Jul 07, 2009 | Toshiba Satellite P105-S6104 Notebook
Toshiba P105-S6004 Laptop will not charge battery
Motherboard repairs are often poorly done and they are expensive except for the simplest jobs like replacing the DC jack. And new motherboards are also generally very expensive. And cheap way out of this is buying a used battery charger or a used working motherboard. eBay is usually the best place to start. Good luck!
Jan 30, 2009 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite A105 Notebook Logo
343 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
