Question about Kitchen Ranges
I am trying to replace the control board on a maytag mer5755qaq and need to remove the heat/visor shield. How do I do this? Please help!
  • 8,197 Answers
There are two screews onder the shield. You need to get level with the shield to see them. Remove the two screews and it should come off no problem. Now to get in to the controll panel you have to pull the oven out and there are two screews on the back in both top corners to get in side to the control board. Good luck
Posted on Dec 16, 2008
Maytag Oven model MER5755QAQ has lock on the display and the oven will not operate.
If one of the position switches on the latch assembly is not reading, the control will sometimes lock because it "thinks" a clean cycle has been initiated, if replacing the control did not fix the lock icon, test the switch... Incorrect temp probe and thermostat failures can also make a control "think" it is in a clean cycle. Maytag Range Stove Oven Door Lock Motor and Switch Assembly WP74008702 Maytag Range Stove Oven High Limit Thermostat 74008715
Jul 06, 2016 | Maytag Kitchen Ranges
Tip
How to change the Heating Element in a Kenmore Elite Electric Dryer?
If the dryer is running but not heating,then the heating element needs to be replaced. The procedure is as follows:--- 1) First of all unplug the dryer from wall outlet.
2) Remove the front service panel of the dryer.
3) After the front service panel is removed. You will see the heating element wires and heat shield.
4) Remove the heat shield by plucking the wires out from the heat shield.
5) Also remove the screws holding the heating element.
6) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
7) Replace the element with a new element.
8) Refit all the parts removed while removing the old heating element properly.
These will help. Thanks.
on Mar 20, 2010 | Dryers
Heat shield rattling is it ok if I just take it off with out replacing it ?
heat shield could be broken or loose missing screws to hold it in place.NO bad idea DONT remove heat shield it protects other components from heat damage.heat shields also protect vechicle floor board from getting too hot causing fire.
Sep 12, 2013 | 2001 Mazda Protege
I have a powermate 6250 generator,model pmo545007-01 ,i've put 4 bridge boards in it. The last 2 boards blew due to engine just all of a sudden going nuts over reving with no let up,this after running...
Heat is the enemy of solid state devices. Please, check that the heat syncs are properly installed and that there is no obstruction to good air circulation around the circuit boards and around the generator. Any heat shields removed to replace the circuit boards need to be reinstalled in the original configuration.
Oct 04, 2017 | Coleman Electrical Supplies
Maytag electric oven Model MER5755QAQ will not heat past 100
Sorry to say but the erc or eoc has gone bad. The oven control is part # 74009212 at about 200.00. Sorry for the news but it is the problem. Hope this has helped.
Feb 02, 2010 | Maytag MER5775Q Electric Kitchen Range
Replacing control board
Dec 16, 2008 | Maytag MER5775Q Electric Kitchen Range
How do I find the control board in a Maytag MER5755QAQ range?
you have to pull the stove out from the wall. There is a plate on the back that you have to take off and it will expose the clock.
Dec 11, 2008 | Maytag MER5775Q Electric Kitchen Range
Too hot
more than likely if it isnt shutting off when it reaches temp. then it probably needs a temp sensor or a EOC (electronic oven control). I have replaced many of these boards in the past , usually there is a relay on the board that is stuck. The relay really isn't replaceable and the whole board needs to be replaced. Does the dispay show the temp that the oven acually is or the temp it is set for?
Nov 05, 2008 | Maytag MER5775Q Electric Kitchen Range
Dryer over heating
ALSO CHECK THAT THERE ARE NO MORE THERMOSTATS AS MOST DRYERS I HAVE COME ACROSS ARE FITTED WITH THREE OF THEM.GOODLUCK.MOHAMED
Sep 12, 2008 | Maytag PYE2300AY Electric Dryer
Mzd2766ges
its located in the upper right corner of freshfood side. sometimes its hard to get to. remove light shield, then heat shield, then the auto damper housing assy. and then 2 scews holding the defrost board,remove the 4/6 wire plug to board carefully. also unplug refridgerator first. good luck.
Aug 27, 2008 | Maytag MZD2766GES Side by Side...
Kitchen Ranges Logo
149 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
