Question about Sony CDX-5090 CD Changer
I can't get the led read out to brighten?
I have this new truck with theis great sounding ssystem in it. the only problem is I can't figure out how to brighten the led screen. I hope there is a trick to this as it is so dim you practically have to hold a lighter up to it to see it to read it in the dark. any helpful hints? thanks Dimlit
    President:
  • 3,130 Answers
Does the dimmer switch in your truck make nthe light in the radio go up and down? if not the instalation was not done properly and someone left off the dimmer wire. If that does work and the brightness does go up and down, you may have an LED or Two out on the radio. Good Luck
Posted on Mar 23, 2007
Replaced stock brake lite with a new led. Why while bike is idling the LEDs are pulsating . Can anyone. Help
The LED's have a very low amp draw and are very voltage sensitive. If you have access to a volt/ohm meter you can read the ohms of your new LED bulb, then read the ohms of your old tungsten bulb. Figure the difference and find a resistor to match this number and install on the ground side of your bulb. This will Load the circuit and should stop the pulsating.
May 14, 2011 | 2007 Harley Davidson FXSTC Softail Custom
1989 Volvo 240DL Sedan My Brake lights cease to increase in lumen (brighten) when depressing brake pedal, however they are lit when headlights are activated. My running lights (headlights &...
lamp failure light on possible because the SECOND filament in your STOP/TAIL Light Bulb is burned out- change one side and check fail lamp again- repeat on other side- fail lamp works off of resistance-burned or blown bulb is only way it lights unless you have a wiring issue
May 03, 2011 | 1989 Volvo 240
I am looking for a cold air intake ssystem for a 2006 scion xa and i don t know which one to get, i like the engineering of the injen and volant but k&n is a save route?
I have always had great success with any product from k&n. They may cost a little more, but like the saying goes "you get what you pay for".
May 02, 2011 | Scion xA Cars & Trucks
I want to doing more brightness.
Hello sounds like your trying to figure out how to brighten your screen. If so, try looking on your keyboard and see if You have specialty function keys. These are usually right on top of your number keys. On mine Its function keys f7 and f8. Just like typing a capital letter except you have to hold the Fn key, usually found in lower left had side of keyboard. Hold down and press function key that shows a sun Up F8 on mine and see if that brightens screen. You might have to press a few time to brighten.
Hope this Helps
Jan 30, 2011 | Computers & Internet
Hello, I got this Model in 2006 and my picture has got dimmer and dimmer. Is their just one bulb that needs to be replaced, and is it the bulb? Thank You!
there is more than one bulb, you need to call samsung to find out just how many. the bulb can be the primary fault , however all plasma tv's will dim more and more over time. It has more to do with the plasma panel though. replacing the bulbs may brighten the picture some however if it were only the bulbs you would have no picture at all. my personal opinion in this case would be to not replace the bulbs, i doubt that will solve your problem even if it does brighten the picture some i doubt it will produce the solution you are seeking. plasma tv's are great but they do have drawbacks, like the bulbs needing to be replaced and the fact that the panels get burn in . the problem you have is more to do with burn in than it does the bulbs. even thought there is no static image in one place ( what people think burn in is only ) the entire panel has " burn in " slightly which dulls the screen. i suggest buying a new tv, lcd or lcd/led to avoid this in the future. you can try to use the same thing they do to fix actual burn in of a static image, that may brighten the screen a little, however in some instances that is the culprit. to truely explain all this it would take a very long time , look up burn in on the internet and read about all the causes and solutions, you will then understand in a rather short period of time.
Jan 09, 2011 | Samsung HL-S6187W 61 in. HDTV
I cannot adjust the monitor brightness, it's too dark..
Since this problem was posted generically.. Monitors, whether they are the old tank style CRTs, the newer flat panel LCDs or the newest LEDs, all have 'Brightness' controls. All are typically marked with what looks like a bright, or radiant light bulb, usually offset to one side, to show that "adjusting the ?? that way" will brighten the screen. Most LCDs are now Menu Driven, so looking for a button that says "Menu" is your starting point. You will need to find your adjusting control and the 'light bulb' to figure out which way to brighten or dim your screen. Once found, adjust to eye pleasing brightness. If your brightness is at 100%, you are on your way to needing a new or used monitor. Typically, there is no Brightness settings in the operating system. Your enhanced video card maybe doing it to you, They usually have their own control center and the types of abilities vary greatly. If you hav a friend that can loan you a monitor, borrow it to test at least the output your monitor is receiving. That will tell you whether you are having a problem with your video card or your monitor.
Aug 18, 2009 | Dell (H5195) Laptop Cooler, CPU Fan,...
Your new hotmail format is blurry and words are on top of other words. Is anyone else having theis problem? Bring back the old format....it was great!
This sounds more like your software settings. Right click on your internet explore desktop icon. Click on properties, than click on accesibility. Select the check box telling your browser to ignore web site font control and size. You can also set your font size for all web pages under the font button in your browsers properties.
Nov 06, 2008 | Computers & Internet
Temperature LED
no way to brighten with out replacing entire clock/control unit.
Feb 23, 2008 | Kenmore 72012 / 72014 Kitchen Range
Picture and sound problem at 21" sony waga color tv
This is due to problem in deflection area and power supply section malfunction. Make one general service by technical person immediately to avoid major transformer failure problem. Since this is initial stage, the cost of repair is probably less.
Aug 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Car Audio & Video Logo
145 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
