Question about Mitsubishi VS-50607 50" Rear Projection Television
Mitsubishi VS-50607 projector
My Mitsubishi VS-50607 has had a broken tuner, we fixed that with a cable box, and then, what we believe, the projector broke. the tv will turn on for a few seconds, NO PICTURE, just a pink screen, and then it will shut off. We have had it for about 8-9 years
  • Anonymous Mar 25, 2009
    it gets on for few min, than shuts off and after that just last on for about one second... after few hours holds on more time and goes back to first situation again
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Posted on Jul 09, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Posted on Oct 06, 2007
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Posted on Apr 09, 2008
  • 4 Answers
SOURCE: I have a Mitsubishi VS-50607 and it will turn on then off.
This solution fromtroylove solved my problem. troylove11
Rank:wizard_s.gif Wiz
Rating: 85%, 1164 votes
Posted on Mar 14, 2009
ladywinn
  • 5138 Answers
SOURCE: how do i clean the projectors and screens of my
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Posted on Sep 20, 2009
My Mitsubishi vs 50607 has blue green and red lines jumping all over the screen what is the problem and fix
You have some bad filter caps in the convergence section of your set or a bad convergence chip
Aug 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs-50707
see a tech you need one they will come and take the panel off and thake the light box with them because you have a circiut problem
Feb 25, 2010 | Mitsubishi VS-50607 50" Rear Projection...
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs-6047 60 in
pull the front panel off, remove the 4 screws holding the inner panel on , then with a screwdriver gently touch the wires leading to each of the the projector bulbs one of these is not getting a good connection , it is the one that has about 6 wires leading from it
May 12, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Wavy picture on television screen
First do the self test on these threads or goto ctechnicians.com
Dec 29, 2007 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mistu VS-50607 Error Code 2-4
C411 and C412 can be the problem, for more info ctechnicians.com
Oct 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
62 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
